Can someone answer this please!!!
Discussion in 'Volvo Forum' started by Tcainmayne, Mar 11, 2019.
  1. Tcainmayne
    Tcainmayne Light Load Member
    55
    11
    Dec 20, 2018
    Ok I’m tryna understand If I had a injector problem this whole time then why when I put my new egr cooler and egr valve on the truck ran good for 2 weeks then the egr cooler pops again 2 more times untill they decided to check my injectors now if that was the case wouldn’t the truck still run bad even when I got all that put on from the jump instead of breaking 2 weeks later and why wasn’t my injectors codes popping up ... I then put new engine harness new turbo actuator new egr cooler new egr value and now injectors how couldn’t the dealer catch this from jump since I kept getting a check fuel filter code they check fuel pump and housing and said all that was good but can somebody explain to me how was the truck still running good with the bad injectors
  3. Sdatruckinginc
    Sdatruckinginc Bobtail Member
    46
    20
    Jan 18, 2019
    Depend on motor and truck I have a Volvo D12 all kinds of codes injectors and others it was bad egr some components Will cause other codes to pop good tech knows this and will check but first hand experience has shown me very few techs only part changers just spent 3 months chasing a power issue on mine to finally find a bad sensor no shops could diagnose it cause no codes good luck
  4. Dino soar
    Dino soar Road Train Member
    4,834
    27,114
    Dec 8, 2017
    Deleted post. Sorry wrong thread
  5. Tcainmayne
    55
    11
    Dec 20, 2018
    Yeah I have a d13 engine and that’s crazy a measly ### sensor smh
    Sdatruckinginc Thanks this.
  6. KB3MMX
    KB3MMX Road Train Member
    3,079
    2,596
    Dec 29, 2014
    Orrstown, PA
    Trucks can run "fine" with weak injectors.
    Most people don't notice a problem until 30-40% power reduction.
    Bad combustion on these emissions trucks beats on the emissions systems hard.
    Remember the old days you ran injectors until they totally gave up.
    On new trucks if you run them that long it trashes the emission system in the process.
    Most injectors have lost a lot of spray efficiency beyond 500k miles and slowly keep degrading until a problem is noticed or they fail.
  7. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    So did you only do all this work at 1 dealership or more then 1? The real issue......getting the initial diagnosis right. Parts changers throwing every part they can until the O/O is bankrupt.
    Tombstone69 and KB3MMX Thank this.
  8. Tcainmayne
    55
    11
    Dec 20, 2018
    Yeah I did it at a dealership basically they went off of codes that was on my truck because of the check engine light and yeah that’s all they doing because thell fix something then 2 weeks later the truck breaks down again with the same check check fuel filter code
  9. Tcainmayne
    55
    11
    Dec 20, 2018
  10. Amram
    Amram Medium Load Member
    448
    235
    Feb 4, 2017
    I have had 8 sets of injectors put in. Last set had a flutter from the very first day installed. Truck has never thrown a single injector code.
    KB3MMX Thanks this.
  11. Tcainmayne
    55
    11
    Dec 20, 2018
    Did you get a check fuel filter light on the dash
    KB3MMX Thanks this.
