Can someone recommend tuning parameters Series 60
Discussion in 'Freightliner Forum' started by rbrauns, May 6, 2020.
  1. rbrauns
    rbrauns Light Load Member
    164
    56
    Dec 7, 2014
    In order to fix a bad ECM tune, every tuner I talked to told me that they won't touch someone else's screw up.
    So I asked Freightliner to put back the factory software. 7 dealers laughed at me and most aren't even sure that they can do that.
    Globocam in Montreal can restore the factory settings. They only charge 2 hours labor so I asked them if they could adjust some of the injector parameters, as well. The software they use can do that but the Freightliner dealer is not a tuner so what would be some good parameters to use?
    The truck has other issues so it might be a while before I can get it tuned.
  3. Brandt
    Brandt Road Train Member
    4,625
    6,359
    Sep 17, 2012
    Yeah Pittsburgh Power can do the job. They even have remote tuners. You go the one of their guys that has a laptop and he calls Pittsburgh Power and they can turned it from Pittsburgh Power. You can always go to their shop also
  4. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    I am a remote tuner, and for what he needs done I think he might need to send his ECM into them.
  5. rbrauns
    164
    56
    Dec 7, 2014
    That's exactly right. A good tuner needs the MCM and CPC. The Freightliner dealer can reflash my ECM but since he is willing to adjust the parameters a but, what numbers would you recommend?
    I'm assuming injector timing and pulse width can be adjusted.
    I could just leave my ECM bone stock but the tuner I want to use is across the country in Alberta and it is dead out there so I may need to live with the stock tune for a while.
