Can you please help with a VIN question
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by FlyingJ mafia, Jul 29, 2023.
  1. FlyingJ mafia
    FlyingJ mafia Bobtail Member
    21
    6
    Apr 10, 2021
    Hello,
    I am looking at a 2000 Peter Built 378
    The VIN is 1XPFDT9X9YD536626
    I believe the Y is for year 2000. Does this mean I need to add an ELD. I was reading that prior to 2000 you will not need one. I know it depends on release date.
    The engine is the 10.3L L6 DIESEL
    Would appreciate your advice.
    Thank you
  3. Sons Hero
    Sons Hero Road Train Member
    3,038
    31,147
    Jan 8, 2021
    Indiana
    The engine will need to be pre 2000. Check the spec plate on that, it will tell you. What transmission does it have? Just being nosy…:)
    FlyingJ mafia Thanks this.
  4. Ridgeline
    22,723
    123,354
    Did you buy it?
    Everywhere I see it was sold for $11k.
    The chassis number is meaningless except if you hand it to the dealer and they print off the original order which will have the serial number of the engine on it.
    Looking at the tag, it looks like a 99 not a 2000.
  5. FlyingJ mafia
    21
    6
    Apr 10, 2021
    I believe RT-18
    Has double frame .
  6. FlyingJ mafia
    21
    6
    Apr 10, 2021
    Did not buy yet. Just looking. I will have to go over and look at the engine tag. I am looking for a truck to haul gravel around my area.
  7. bad-luck
    bad-luck Road Train Member
    3,435
    6,326
    Nov 16, 2013
    Baltimore, Maryland
    ELD is required for trucks 2000 and newer, UNLESS they have an engine year 1999 or older, then the truck is exempt from an ELD. Truck years 1999 or older are ELD exempt.
  8. mitrucker
    mitrucker Road Train Member
    5,482
    10,300
    Dec 15, 2010
    Lapeer, MI
    It is a 2000 MY truck. As mentioned, find out if the engine is 1999 or older.
    FlyingJ mafia and Sons Hero Thank this.
  9. Diesel Dave
    9,663
    32,737
    Jan 20, 2010
    Hesperia, Ca.
    You're exempt from ELD if you run LOCAL under 100 or 150 miles radius. However, you have to keep track of your time.
