Cancelling signal flasher cancel - can it be done?
Discussion in 'International Forum' started by TruckinCatKarma, Nov 13, 2019.
  1. TruckinCatKarma
    TruckinCatKarma Bobtail Member
    22
    Jun 18, 2011
    The boss just supplied us with new ‘20 LT’s. First truck I’ve ever had with signal flasher cancel feature. I hate it!!! It shuts off way too soon and if navigating right turns, it shuts off when I don’t want it too at all. Can it be disengaged?
  3. Snow Monster
    Snow Monster Medium Load Member
    543
    1,297
    Feb 9, 2019
    Well............, you might be able to break it so it doesn't cancel, I'm not sure.
    Probably not a good thing to do, but you could try holding the signal stick in left turn mode and crank the wheel in the opposite direction.
    Don't know what else it might break, imagine it could be disastrous with these new techno trucks and all the doodads in the steering column.
    Rideandrepair Thanks this.
  4. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    Maybe. Call the dealer and ask. Otherwise, you may invalidate your warranty.
    Cabinover101 and Rideandrepair Thank this.
  5. disoba
    disoba Light Load Member
    53
    59
    May 7, 2013
    I have that on my truck and I hate it!. it cancel the signal in the middle of a turn when is need it the most...
  6. TruckinCatKarma
    22
    Jun 18, 2011
    Exactly! It shut off on me on a jughandle right turn in a busy intersection during rush hour and an oncoming car wouldn’t back up. When they finally did back up the driver screamed at me that my turn signal wasn’t on. I hadn’t noticed that it had shut off bcuz I was busy focusing on not clipping anything or taking a lamppost down, lol!! I guess I’ll have to hold it down next time.
    Cabinover101 Thanks this.
  7. TruckinCatKarma
    22
    Jun 18, 2011
    Our company leases the trucks from Ryder. I will be asking about it next time it goes in for PM.
  8. TruckinCatKarma
    22
    Jun 18, 2011
    Geeze I hadn’t thought of that. Idk if I wanna try that. Could get myself in a load of trouble if it breaks the signal or anything else.
  9. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    They wear out fast if you are stuck sitting in truck for a long time waiting for fcfs door and work it back and forth till it Quits Ft. tires had spots it from tires ground into pavement ?
  10. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    I would get a pair of pliers and snip the #### thing. Then install a aftermarket flasher.
  11. buddyd157
    buddyd157 Road Train Member
    13,576
    34,885
    May 25, 2017
    under a shade tree
    messing around with safety features, no matter how much YOU hate them can get you into hot water with the insurance companies, and the lawyers, should you get into an accident.
    they will show that YOU disabled a safety device, making YOU guilty of any accident.
    make your displeasure known to the boss and let him decide what to do about it.
    other option to consider..??
    buy your own truck, remove all the safety features YOU want, and hope and pray you do not get sued, for disabling safety equipment...
    the end result in BOTH scenarios..??
    leave stuff alone.....
