Cannot tighten flywheel bolts anymore
Discussion in 'Ask An Owner Operator' started by MyLotion, Jun 29, 2022.
  1. MyLotion
    MyLotion Bobtail Member
    23
    16
    Aug 20, 2019
    Per the Volvo service manual of a 2006 D16 Volvo VT880, the flywheel bolts should be torqued to 44ft +- ft/lb and then another 120 +- 10 degrees. I am only able to make it to about 60 degrees after applying the 44ft/lbs of torque.
    Is this fine? Am I to apply blue loctite to these bolts as well?
  3. roundhouse
    roundhouse Road Train Member
    3,213
    7,334
    Jul 11, 2018
    You using new bolts ?
    Or reusing the old bolts ?
    Do the specs call for new bolts ?
    Alot of the later model stuff requires new bolts because the old ones are designed to stretch .
    77fib77 and MyLotion Thank this.
  4. AModelCat
    165,051
    Not to be a smart### but if it says 120 degrees, I'd make sure its 120 degrees. If 60 degrees were fine, the manual would have said 60.
  5. MyLotion
    23
    16
    Aug 20, 2019
    I am using the old bolts
  6. MyLotion
    23
    16
    Aug 20, 2019
    And nothing in the manual calls for new ones
  7. MyLotion
    23
    16
    Aug 20, 2019
    You dont sound like a ######## at all. I agree with you. I feel like I'm going to snap a bolt if I go any farther.
    AModelCat Thanks this.
  8. REALITY098765
    REALITY098765 Road Train Member
    1,520
    1,350
    Sep 17, 2017
    What is a torque-to-yield bolt? It is a one-time-use fastener that is designed to stretch during the torquing process (installation). Because of this stretching, the integrity of the bolt is compromised. These bolts cannot and should not be reused due to the stress caused to the bolt during its first installation.Feb 12, 2020
    RedForeman, MyLotion and AModelCat Thank this.
  9. Elroythekid
    Elroythekid Road Train Member
    2,621
    5,675
    Sep 9, 2010
    Halifax Nova Scotia
    mitrucker Thanks this.
  10. Nostalgic
    Nostalgic Road Train Member
    1,815
    20,015
    Mar 6, 2017
    PA
    Another thing to add, since I have no clue how much experience or knowledge you have, but 120 degrees is just 2 flats. I may or may not know a guy that got confused on that stuff in his younger years and wondered why he was breaking bolts lol. 44ft lbs and 2 flats is probably going to land somewhere around 150-200 ft lbs if my guestimation is close.
  11. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    those are "torque to yield" fasteners (or bolts) they came out decades ago, when i was turning wrenches, and many mechanics were reusing them, and had HUGE problems with them breaking.......
    always buy FACTORY NEW from the dealership NEVER from eBay or anyplace else that might sell you Chinese made ones.
    MyLotion and Last Call Thank this.
