Can't build air
Discussion in 'Kenworth Forum' started by tsavory, Dec 12, 2013.
  1. tsavory
    tsavory Road Train Member
    1,910
    1,860
    Jun 4, 2013
    Paoli, IN
    ok I have a 97' KW t2000 with the 3406e. I have a problem building up my air it seems that every cold weekend I park and first go it takes forever to build up last weekend had to let it run for over an hour to get it up once I get it built up I can go all week never having a problem even after shutting off the truck for a few hrs. Warm weekends no problem at all building pressure.
    I do hear a leak coming off the backside (3/8 whole threaded) of the Unloader ( I think that's what it is a round tube with a cap and under the cap a threaded rod with a 10mm nut) anyways this morning after a 10 hr break at the house so it was off I can't get the air to build above 60 PSI I plugged the hole for a couple and still would not build air unplugged still no change after an hour and a half no air I gave up shut it down.
    Only two leaks I can find in the system is one the one on the unloader and the second it the primary low pressure valve till It get built up both quite once built up. neither seem to slow it down if truck unless its been off for several hours and is clod get above thirty and even though they act the same I build pressure right.
    thanks up front for any suggestions
    Tsavory
  3. Cummins_444
    Cummins_444 Medium Load Member
    605
    1,014
    Apr 28, 2008
    Northwest, IN
    Change your air governor.
  4. Newtothis25
    Newtothis25 Bobtail Member
    17
    6
    Sep 9, 2013
    Sounds like an air dryer or purge valve to me
    tsavory Thanks this.
  5. tsavory
    1,910
    1,860
    Jun 4, 2013
    Paoli, IN
    thanks just had a buddy stop by that was an o/o for years he said that the governor is stuck.
    first time for everything all other air problems where an air-dryer that went bad and lost all air in the middle of the street fast and break chambers and air line leaks first time with something on the compressor.
    thanks for your input.
    Tsavory
  6. deskdriver
    deskdriver Light Load Member
    241
    141
    Aug 6, 2013
    Agree with the air governor, also when its cold make sure you drain the water out of your tanks often, that can cause issues to
  7. tsavory
    1,910
    1,860
    Jun 4, 2013
    Paoli, IN
    I do at least three times a week.
  8. tsavory
    1,910
    1,860
    Jun 4, 2013
    Paoli, IN
    Update it was the governor went got a new one replaced and back on the road lost my original load but hey got me on something with in minutes of letting them know I was back up and able to go love it hardly ever any waiting for a load.
  9. Pinner
    Pinner Medium Load Member
    410
    201
    Feb 14, 2010
    B.C.
    Also if the desiccant filter in the air dryer hasn't been changed in a few years they can get plugged up with oil when it's cold.
  10. fortycalglock
    fortycalglock Road Train Member
    6,158
    6,592
    Jun 25, 2011
    Tourist Town, FL
    If you didn't get a genuine Bendix governor, go buy one now, you'll probably need it. They're so cheap and small it doesn't hurt to have one in the side box anyway.
  11. toady
    toady Bobtail Member
    Thomson, Georgia
    I'm having somewhat the same problem. My Pete won't build pressure at all. I rebuilt the compressor and unloading valve. The compressor pumps air, but won't build pressure in the tanks. Take the main compressor line off, the compressor is pumping away. Hook the main line to my shop compressor, I can fill the truck's tanks. No leaks. Hook the line back to the truck compressor...nothin'. Anybody wanna take stab at that?
