Cascadia 2012
Discussion in 'Freightliner Forum' started by MackRookie, Aug 6, 2019.
  1. MackRookie
    MackRookie Light Load Member
    193
    25
    Nov 30, 2017
    Canada
    Getting code cab 33 spn 522006 fault 5. Ac has stopped working also.
    Anyone give me an idea what's wrong?
  3. Opus
    132,733
    AC is broke..
    You're welcome
    kemosabi49 Thanks this.
  4. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    cab 33 spn 522006 fault 5 means :
    A/C Compress or clutch -Current below normal, or open circuit / conn X19, pin 6 / No load is connected
    Possible Causes
    1. The wiring harness to the connected load is open
    2. The connected load is not functioning properly
    1. Check the wiring harness to the connected load
    2. Check the load
    1. Battery voltage is greater than 9V and smaller than 16V
    2. A/C compressor clutch is switched from active to inactive
    most likely a/c clutch is gone. new Denso A/C compressor may be needed. If you know how to use multimeter check to see there is resistance on coil ends. separate a/c clutch is not available at dealers for Denso compressors.
    Opus Thanks this.
  5. MackRookie
    193
    25
    Nov 30, 2017
    Canada
    I did the ac reset. The code went away but I still have warm air coming from the ac
  6. Opus
    132,733
    Then you're out of freon or your compressor is shot. Probably 'A', and you have a leak
  7. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    do you know how to measure resistance of circuit ?
  8. MackRookie
    193
    25
    Nov 30, 2017
    Canada
    No I dont. Maybe my best bet is to take it in for ac service
