Driving though TN today, AC was blowing semi-warmish, definitely not up to snuff. Even floored on 8/recirculate it wasn't doing the job. I tried shutting it off for a few, then back on, something I have noticed that needs doing when you idle too long and seems to peter out. No help there, just blowing out maybe 60° air. Oddly the voltage was down a tad, 13.8-13.9 v. Once parked, I did the "knob reset" routine and now once again you could hang fresh meat in here. Voltage is back up too. Possibly involved: a new alternator, 2 new batteries, and a Freon recharge not 5 days ago. Advice?
Cascadia A/C weirdness
Discussion in 'Experienced Truckers' Advice' started by RustyChops41, Aug 11, 2017.
Page 1 of 4
I'd check the wiring harness connectors at the ac compressor and the high pressure switch and anywhere else you see a connector that may be involved to carry the signal to the compressor
I'm guessing when it wasn't blowing cold air that the compressor clutch was not engaged?
Could they have put too much refrigerant in causing the system to protect itself?
Could be anything like a bad temp selector dial/switch. Is the "snowflake ligh" lit an the ac switch (button)?
Did it gradually blow less cool? Or was it instantly? If gradually, this indicates the evaporator core is freezing over. This happens a lot when they run low on refrigerant. But if this was the case there would be little air coming out the vent outlets.Last edited: Aug 11, 2017
fargonaz Thanks this. -
Snowflake lit good. The company owner declined to replace that high pressure switch when the other repairs were done. The shop advised him it was also bad, as it was only keeping the compressor clutch engaged for 5-10 seconds at a time. But system.was still working fine for 2500-3000 miles until today. Been parked an hour, its an igloo in here. Another odd change was that after last weeks shop visit, the aux cooling fan ( that roars loudly when coolant temp gets higher climbing grades) was/is now cycling on and off with the A/C compressor clutch engagement, without fail. Never been in a Cascadia that acted like that, including this one, until last weeks repair visit. Hmmmm?
My '12 is doing the same exact thing. I haven't done any troubleshooting on it, because it comes back so quickly. Just so many other pressing maintenance items occupy my home time.
Lepton1 Thanks this. -
It will probably do it again and on the worst possible day.
Does the system ever kick the engine fan on when idling or driving at low speeds (as it generally should if operating correctly and on hot days)Last edited: Aug 11, 2017
Low speeds, yes, often. But never heard it come on at idle, not in over 150K miles in this particular unit.
I drove a 12 and a 16. I think it's a glitch in the ecm. Resetting the knobs was always the trick. Didn't happen often. And at least it worked which is better then taking to repair shop.
Get used to it and don't complain. It's a quick fix.
Fuel sending units is another fault. Replaced 3 times in 1 year. Have no idea on the last year since I left them.Last edited: Aug 11, 2017
WTH are you guys talking about "resetting the knobs" and such? This is all new to this dumazs driver.
Blackshack46, whoopNride and drivingfool Thank this. -
Turning the HVAC fan off, then back on again, is resetting the knobs. The trouble today is that I did this over a dozen times today while driving, to no avail. Once parked, it worked the 1st time. And I do have yet to drive one that didn't have bad fuel sending units, always reading 7/8 full even when full, and showing 3/4 within 25 miles from the truck stop after fill up
The reset cant be done till the park brake is on; fan off, heat to full and direction control to last setting anticlockwise then push the recirc button and the ac button together, hold them down till they start to flash and release. You'll hear the actuators and control flaps moving about, and when the lights go out its reset.
But I doubt that's your ac problem, (although the hvac units do wear out and they are expensive and 9 hours to change out) I had a load of problems with mine until recently, first thing to check is the rear outlet, when the front goes weak does the back still blow cold?TA Transport Thanks this.
Page 1 of 4
