Cascadia Antannas mount bracket?
Discussion in 'CB Radio Forum' started by Intothesunset, Jun 29, 2019.
  1. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    Where can I pick 2 up for the mirrors??
    Where does the factory coax wire go to?
    Can Antannas be mounted behind bunk?
  3. wolverine11
    wolverine11 Road Train Member
    1,628
    1,234
    Apr 1, 2015
    Without knowing the year of your truck if you dont see antennas on the side of the cab then the antenna is integrated into the roof, good for about 3 miles of range. If you wanted to use the Wilson brackets , they sell those in most truck stops or there are other brands that typically sell in cb shops. If you are leaning to go that route there are several threads about Cascadia Antennas on this forum that have been posted over the past several years.
    rabbiporkchop Thanks this.
  4. Intothesunset
    2,289
    4,880
    Apr 15, 2019
    truck
    I tried searching for posts about Cascadia mirror Antannas mounts but to no avail.
    The Cascadia is a 2020 not sure when they changed the mirrors.
    I have the radio hooked to factory coax and nothing but static is all I hear.
    Have not tried the mic yet for fear of damage.
  5. wolverine11
    1,628
    1,234
    Apr 1, 2015
    Go back around 2014/2015 and search for thread by Mike511 titled cascadia antenna solution.
    rabbiporkchop and Intothesunset Thank this.
  6. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    A 14/15 solution will not work re ant bracket on latest n greatest...
    Intothesunset Thanks this.
  7. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Wa
    Walcott cb shop in iowa sells them..Dont know where else...They have a killer selection of stuff just not a fan of their tech work..
    QuietStorm and Intothesunset Thank this.
  8. rabbiporkchop
    9,678
    6,546
    Feb 9, 2012
    Wapwallopen, Pa
    They could be mounted underneath the vehicle dragging on the ground but that doesn't mean they'll work very well under that set of circumstances. Just because you can bolt it to something doesn't mean it's going to function correctly.
  9. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Think of your out going signal as a rock in a bucket just goin nowhere and just maken noise..If your pulling a flat bed well then you will have signal all behind you but no range infront..
  10. Intothesunset
    2,289
    4,880
    Apr 15, 2019
    truck
    Genius engineering by Freightliner.
  11. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Freightliner didnt even come up with that idea..Forget the name who but it was german i think maybe even the sweeds..
