Cascadia check engine lights
Discussion in 'Freightliner Forum' started by Edward H, Sep 30, 2019.
  1. Edward H
    Edward H Bobtail Member
    I drive a 2019 Cascadia with a DD13. For the last 6 weeks, my truck has been in and out of the Freightliner dealership for check engine lights coming on and derating my engine by 10%. The code says it's the jake brake stage 2 low. It will come on no matter if I'm driving or parked and idling overnight. Nobody can figure out what's going on. The codes are 1073 4 & 521027 9. I'm thinking it's a short somewhere because while my truck is shut off, I can turn my sleeper done light on and immediately my factory installed bunk heater control panel lights up and then after 5 seconds, my sleeper light goes out by itself. Could the 2 be connected? I've looked everywhere for a short. Anybody having similar problems know where I can look?
  3. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,081
    Sep 24, 2019
    Raleigh, NC
    Sounds like you have something grounding out.
    Does your windshield leak by chance?
    One of ours had water get into his fuse box and shorted out a SAM module. All his exterior lights would flash like he had the 4 ways on.. but it was every single light.
  4. Edward H
    That was my first thought but we've had a very dry summer. So, with no rain to leak into the SAM module, I'm stumped.
  5. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    hat dealer says about this issue?
  6. Edward H
    Not much. Each time they say they fixed it by replying the dozer value, or update computer software, etc. But every time I get it back, same codes pop up within 24 hours. They dumbfounded now.
  7. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    call Daimler complain hot line. say them if its not going to be fixed you will hire a lawyer and sue them. Also mention that you will share this situation on social media.
  8. tubopopson
    tubopopson Bobtail Member
    I drive a 2017 freightliner this engine code SPN 1705 FMI 7 can someone pls explains what it means thanks
