Cascadia Coax
Discussion in 'CB Radio Forum' started by skibum_63, Jul 27, 2011.
  1. skibum_63
    skibum_63 Road Train Member
    2,176
    919
    Oct 12, 2007
    somewhere, USA
    So does any one know , if the the coaxl on Cascadia are tied into into the in dash satalite radio? and if so which antanna, is used for the sat radio, , which is used for the cb. Been having trouble with both. CB, people can barely hear me,(yes it was peaked turned recently,but before i moved into this truck) and the sat radio, loses signal wheni'm headed in a northly direction, or have trees on the right side.
  3. mike5511
    mike5511 Road Train Member
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    As long as you are running the factory coax, you are not going to receive or xmit much more that one mile. It's junk and the only cure is a dedicated coax to a good antenna, not the cb,fm,am, weather band, sat combo antennas than come on the Cascadia.
  4. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    CORRECT ......
    I don't know how they think it is going to work but any multiband antenna
    is as best a dummy load .....
  5. mike5511
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    Not only that but the coax goes through 8 junction boxes per side. That is a loss of a couple db at every junction! They lowered the junction boxes to four per side on our newer 2010s and it improved some. Still sucks though.
  6. WX4JCW
    WX4JCW Light Load Member
    161
    67
    Nov 20, 2009
    Orlando, FL
    The Satellite antenna on my 2009 Cascadia is not tied to the CB Coax, it runs through the Dashboard, and a word of warning on these cheap trucks, my satellite antenna was shorting against the fuse/SAM panel and caught fire (No Joke) when we got the truck, so if you have a Cascadia pull the glove compartment and check the antenna wire (it has a yellow connector there) and make sure its not shorting out
  7. mike5511
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    Ours don't have the satellite ant. feature. I just threw that in there because they might as well have, they got everything else!
