Cascadia DT12 Transmission problem
Discussion in 'Freightliner Forum' started by Ea4transport, Sep 19, 2018.
  1. Ea4transport
    Ea4transport Bobtail Member
    4
    Whenever the transmission is in Ecoast it has to try several times to put it back into a gear(when I press the brakes or accelerate)whether it be 12th or 11th gear. ( normal upshifting and downshifting is fine)
    Same thing happens when I turn the engine brake on and it tries to downshift the gear but it won't without several tries.
    So far I have changed the clutch, TCM , Slipt Pin, fly wheel, actuator and counter shaft clutch. We have reprogrammed it several times to recalibrate it.
    Any idea at this point what should I do except changing the whole Transmission.
    Thanks,
    Sunny
  3. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    I am just wondering how much have you spent on repairs? I mean changing the TCM , Slipt Pin, fly wheel, actuator, counter shaft clutch and for reprogramming , calibration.
    AlexD13 Thanks this.
  4. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Here's a simple solution..... Disable Ecoast.
    How this is allowed in a AMT by law is beyond me!!
    This is the exact reason it will cost people their lives when it can't find a gear on a large downgrade !!
  5. Ea4transport
    4
    I have spent a lot on it....I'm gonna have to replace the transmission.
  6. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    I would change the truck.. get a truck with manual transmission.
  7. Ea4transport
    4
    And I thought I would get a reasonable solution here.
    Thanks
  8. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    Does it behave any better after you reprogram it? I mean for a short time afterwards?
    I drove a tuck that did that. It was from Omnitracs messing things up. I would unplug the data connection or the power from the QC black box and the problem would go away... Something wasn't right.
  9. Ea4transport
    4
    I switched the it with another truck and it did the same to the other truck. So it's confirmed now that it's the transmission itself.
  10. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    men you must be from different world. the manufacturer does not know how to fix his product. why do you think you will find solution here ? get rid of that junk. you are not the only one who have problems with dt12 .
