Cascadia eaton 10-speed, odd noise?
Discussion in 'Freightliner Forum' started by PermanentTourist, Apr 27, 2021.
  1. PermanentTourist
    PermanentTourist Heavy Load Member
    749
    882
    Nov 9, 2016
    48 states + Canada
    Lately I've noticed that my transmission has been making an odd noise that I can best describe as "tractory"?
    In all gears except for 9th for some reason?
    9th is nice and quiet...
    Weird.
  3. AModelCat
    166,494
    Sounds like an overdrive 10 speed. 9th being direct would put power straight through with no load on the countershafts.
    Makes me wonder if there's a countershaft bearing starting to go?
  4. PermanentTourist
    749
    882
    Nov 9, 2016
    48 states + Canada
    Any idea as to how difficult this is to repair?
  5. God prefers Diesels
    4,198
    22,269
    Jun 26, 2020
    South Texas
    You have to pull the tranny and bell housing to get to the front ones.
    PermanentTourist Thanks this.
  6. PermanentTourist
    749
    882
    Nov 9, 2016
    48 states + Canada
    You think there's a chance it might just need a transmission oil change? I don't think I ever done it in this truck for the 150000 miles I've had it...
  7. God prefers Diesels
    4,198
    22,269
    Jun 26, 2020
    South Texas
    Don't know. But a five gallon bucket of 50wt is cheap. Takes about three gallons to fill it. I recommend buying a bucket pump. They're about forty bucks.
  8. Smellfunny
    Smellfunny Road Train Member
    1,446
    969
    Jan 28, 2012
    South Carolina
    Have you checked the gear oil level? Usually when they sound that way they are low or out. Does it make the noise at idle? Does the noise quit if you mash the clutch down for a minute?
  9. Joyce's Volvo
    Joyce's Volvo Light Load Member
    117
    155
    Jun 28, 2016
    A model is mighty close , pop the filler plug and see where the oil level is , should be up to bottom of plug , if it's way low ,may be too late , upper bearings may need replacing. Get a magnet on a flexible handle and move it around in the bottom of the tranny , will be small wear particles ( normal ) ,bigger pieces may be bearing flakes or bearing cage. Flaking or cage gone will enable it to growl.
  10. Pashka413
    Pashka413 Bobtail Member
    Just wondering if you ever figured out what it was. I’m having the same issue with my truck.
