Cascadia egr fault code problem
Discussion in 'Freightliner Forum' started by Cascadia13, May 5, 2023.
  1. Cascadia13
    Cascadia13 Bobtail Member
    8
    I have a 2013 cascadia with a dd15 I keep getting code
    Eng 2 001 spn002791 Egr valve cntrl 14
    with a check engine light it comes on and off periodically We’ve already replaced the engine harness, ecm, delta pressure sensor, egr valve and actuator
    The code will disappear for about 5-6 miles and then the code still keeps coming back on do you have any suggestions what it can be? Really tired of throwing parts at it at this point and have no idea what else it could be
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
  4. Nonames~usernumber
    Nonames~usernumber Bobtail Member
    May 6, 2023
    Have you cleaned the doser injector. Carbon build up. 12mm and 14mm wrench. Carb cleaner wool scrubber
    Cascadia13 Thanks this.
  5. JB7
    JB7 Road Train Member
    1,029
    1,818
    Dec 13, 2022
    Laurel, MD
    At this point you have 2 options. 1 - Either methodically go through the troubleshooting steps that uncleal13 posted. 2 - Step 10 mentions to reprogram the MCM. That looks like the only thing in the steps that you have not done.
  6. Cascadia13
    8
  7. Cascadia13
    8
    I have not cleaned the doser injector will probably try this next
  8. Cascadia13
    8
    We reprogrammed it and same issue so I’m thinking it might be an electrical issue where the valve isn’t getting the actuator isn’t getting enough power or something similar
  9. slow pok
    slow pok Light Load Member
    144
    212
    Oct 27, 2013
    lizela ga
  10. Cascadia13
    8
    Anyone think it can be the ACM?
  11. Cascadia13
    8
    It did end up being the ecm and apparently the new ecm from freightliner was defective ‍♂️
