Cascadia electrical issue
Discussion in 'Freightliner Forum' started by Kbutch, Sep 8, 2016.
  1. Kbutch
    Kbutch Bobtail Member
    2014 cascadia. Panel lamps don't work unless drivers door is open. Dealer in reno installed New msf installed but no fix. All switchs blink several times when headlamps first turn on. Can't find any short or fuse issue. Please help
  3. thejackal
    thejackal Road Train Member
    1,359
    1,456
    Mar 1, 2014
    detroit mi
    Sounds like a short to me. Check the door wiring. Maybe a pinched wire in the door harness?
  4. Animosus
    Animosus Heavy Load Member
    734
    2,916
    Dec 7, 2015
    SE Wyoming
    Did they forget to program the MSF when they installed it and double check that the parameters were set correctly?
  5. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    yes. not correct parameter setup !
