Cascadia help
Discussion in 'Experienced Truckers' Advice' started by Scott72, Dec 29, 2014.
  1. Scott72
    Scott72 Road Train Member
    2,747
    1,758
    Apr 7, 2013
    When you shut down the power with the load disconnect switch, does it shut down the power to the engine block heater also? It's going to get below zero here at home, and I always shut down the main power when I'm parked for 4-5 days, but don't want to kill the power to the engine heater as I have it plugged in. Thanks!
  3. Voyager1968
    Voyager1968 Road Train Member
    2,378
    2,907
    Sep 11, 2008
    I know it shuts down everything INSIDE the truck as I'd always have to reset my clock when I came back on duty, but I'm not sure about outside the truck. I'm guessing...and I really do mean guessing, that since you are plugging the block into shore power, it may still heat the block up even if the main power is shut off. Hopefully someone with more info will respond to you.
    Good question though.
  4. Scott72
    2,747
    1,758
    Apr 7, 2013
    Our maintenance dept said it will still heat the engine, but I sensed some hesitation in his voice so i want to be sure as it's suppose to get nasty cold here the next few days.
  5. rexmanno
    rexmanno Light Load Member
    56
    47
    Apr 6, 2013
    If you plug it in after the engine has had a chance to cool off, then when you plug it in you should hear it start to heat up the water, it will be a light hissing sound.
  6. Scott72
    2,747
    1,758
    Apr 7, 2013
    When I initially plugged it in I heard a little spark, so knew it was working, however, I then shut down the master power.
  7. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    The 120 volt AC plug is wired directly to the oil pan heater, block heater only. The master shutoff is for 12 volt DC circuits only.
    Scott72, magoo68 and kylefitzy Thank this.
  8. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Right answer
    Scott72 Thanks this.
