Cascadia idle(issue?)
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by allendriven, Jan 18, 2020.
  1. allendriven
    allendriven Bobtail Member
    45
    30
    Aug 10, 2019
    Wherever
    I'm not a mech, just a dumb company driver, but figured this would be the place to get an answer. 2018 FL Cascadia, DT12 Detroit automatic. Sometimes when the optimized idle is set and I bump the rpms to 900, it will suddenly jump to 1250 rpms and run that way (sounding really weird, like the timings off) for a couple of minutes. When it does this the temp goes up to the cut in for the engine fan. Thought it might be regen but the instrument says soot level good. It just doesn't sound right. I'd hate to take some shrapnel through the firewall while I'm sleeping. Runs fine otherwise. Is this normal?
    Upinsmoke Thanks this.
  3. dunchues
    dunchues Medium Load Member
    558
    961
    Mar 23, 2012
    new brunswick
    Yes. Its doing as parked regen, just let it get on with it and dont stop the motor before it finishes its cycle and drops back to normal idle.
    Upinsmoke and allendriven Thank this.
  4. allendriven
    45
    30
    Aug 10, 2019
    Wherever
    It d doesn't drop down, just shuts off from there. About shakes me out of my bunk. Too many comeputers on these things now. Thanks
  5. Brandt
    Brandt Road Train Member
    4,635
    6,376
    Sep 17, 2012
    Sounds like a parked Regen to me also. It normally takes about 20 minutes. It will start at every 6 hours engine idle time.
    allendriven and Upinsmoke Thank this.
  6. Upinsmoke
    Upinsmoke Medium Load Member
    612
    1,206
    Feb 26, 2019
    Why do you bump the idle up?
  7. allendriven
    45
    30
    Aug 10, 2019
    Wherever
    Because the engine won't warm up enough to blow heat in the cab.
  8. allendriven
    45
    30
    Aug 10, 2019
    Wherever
    I'm assuming that's why it had idle adjust. Owners/operators manual doesn't explain ****. Just tells you it is equipped with it.
  9. Brandt
    4,635
    6,376
    Sep 17, 2012
    The optimize idle system has a thermostat in the sleeper you turn on for heat or a/c. When optimize idle is on it will monitor the batteries and engine oil temp. Start to recharge the batteries or keep engine oil warm
    Then you can have sleeper thermostat and it will keep the cab/sleeper temperature also. My current truck had the battery systems. It had 8 batteries and they run electric a/c and it has coolant heater for winter. It will heat coolant and heat sleeper and engine block. The batteries last about 6-7 hours. Then at 12.2 volts the engine will start and run 2 hour to recharge batteries. I have noticed since it 2 hour to recharge the batteries. If I'm doing a 34 hour reset on the 3 battery recharge cycle at 6 hours engine idle time. It will do a parked Regen
  10. Brandt
    4,635
    6,376
    Sep 17, 2012
    I'm Regen now soot Level is low. I don't think the system waits till it full it just automatic does a Regen ever 6 hours. Maybe that why is only 20 minutes vs the older trucks it was 45 minutes.
