cascadia possible overhaul
Discussion in 'Freightliner Forum' started by 4noReason, May 11, 2018.
  1. 4noReason
    4noReason Road Train Member
    2,394
    752
    Nov 29, 2012
    ok so my truck is in shop. im driving i hear tok tok tok. smoke loses power. im on shoulder within seconds. i check oil dipstick and smoke coming out oil looks fine. i check again after 15 min and oil and coolant mixed. coolant is slowly going down. 715k miles. and oil dripping from bottom of engine. a puddle. so im preparing for worst. crankshaft, pistons, head. anyone had this experience yet?dd15 2012.
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    See where your oil is coming from, might just be a bad oil cooler.
    4noReason Thanks this.
  4. gto kid
    gto kid Bobtail Member
    14
    9
    Jul 10, 2011
    I was thinking oil cooler too especially if a Cummins I’ve had them go bad
  5. 4noReason
    2,394
    752
    Nov 29, 2012
    i doubt. trust me. tok tok noise is something bad. gonna be screwed
  6. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    If you pulled over when the sounds started you may have saved crankshaft?
  7. 4noReason
    2,394
    752
    Nov 29, 2012
    i hope i hope. but i dont get lucky much.
  8. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    so what was the broken part? window on block ?
  9. 4noReason
    2,394
    752
    Nov 29, 2012
    i had pistons and rocker arms replaced. he replaced lots of other things too. but now im having huge high oil pressure issues. its very very high then stop light comes on. and im having some coolant leak. not sure what this could be. getting ecu 0 and cab 33 fault
  10. baha
    4,137
    2,837
    Jul 25, 2013
    ga
    You need to send off a oil sample, then use a oil press gauge that you put in the block or a new oil press sensor to be sure what the real oil press is, how is the rebuilt motor running power wise?
  11. 4noReason
    2,394
    752
    Nov 29, 2012
    its great. strong! issue is i cant go far without stop light goin off. u think its oil pressure sensor?
