Cascadia Warning light
Discussion in 'Trucks [ Eighteen Wheelers ]' started by landy77, Jun 11, 2011.
  1. landy77
    landy77 Light Load Member
    129
    27
    Sep 18, 2010
    Biloxi, Mississippi
    I have a 09 Cascadia and there is a warning light I cant find what it is for. It looks like three lines going to a swirl with two broken lines going up and down.
  3. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    DEF...or your regen and/or exhaust temp sensor is showing excessive temps.
    Check you manual or go online for a PDF manual about the "idiot" warning lights on the dash.
    Strider Thanks this.
  4. Strider
    Strider The Info Monster
    137
    1,996
    Aug 30, 2010
    Kansas City
    otherhalftw Thanks this.
  5. landy77
    129
    27
    Sep 18, 2010
    Biloxi, Mississippi
    Thanks, I hate the company maint shop by the way
  6. Heavyd
    Heavyd Road Train Member
    7,826
    6,274
    Feb 4, 2009
    Sounds like the warning light for the DPF. Your truck needs a regen.
  7. ironpony
    ironpony Road Train Member
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    Yeah, it does. Regens are automatic, and the folks at Freightliner I've talked to all mention that parked regens shouldn't start happening until well over 500k miles.
    They do have a problem with something called the intake throttle control valve. Looks like a large butterfly plate valve that's controlled by a solenoid. The solenoid goes bad, causing the valve to lock open - and that will prevent an automatic or parked regen from happening.
    If you get a check engine lite, or the engine malfunction indicator along with it (and associated flash codes) you'll need to get into a Freightliner or Detroit shop ASAP. Eventually it leads to the engine shutting down.
