cascadia wont high idle
Discussion in 'Freightliner Forum' started by 4noReason, Aug 26, 2017.
  1. 4noReason
    4noReason Road Train Member
    2,401
    754
    Nov 29, 2012
    any idea on why a 2012 cascadia wont high idle? cruise works. air filter new as well
  3. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    it is setup not for high idle. the dealer can change settings of engine.
    QuietStorm Thanks this.
  4. Bro_Dave
    Bro_Dave Medium Load Member
    530
    523
    Nov 5, 2013
    It cost me $95 to change it.
  5. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    usually not programed to idle from dealer need to get it changed.
    4noReason Thanks this.
  6. 4noReason
    2,401
    754
    Nov 29, 2012
    it used to idle. but stopped. so i think its somethin else. it idles. just not high idle
  7. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    does engine brake and cruise work good.
  8. 4noReason
    2,401
    754
    Nov 29, 2012
    yup. i dont recall when high idle stopped. i assume between may-july
  9. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    this is strange it could be a clutch switch but it doesn't make sense then it cruise and engine brake shouldnt work, check if parameters are set up properly if someone did ecm update or anything like this they probably removed it and never programed back in
  10. 4noReason
    2,401
    754
    Nov 29, 2012
    do you fix this kinda stuff. idk if i can take it to dealer. once they plug in my ecm they will see. emissions diagnostic. so id rather avoid dealer
  11. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    ya come by i can try to see what i can do it shouldnt be an issue
