Cat 3406b high temp
Discussion in 'Trucks [ Eighteen Wheelers ]' started by AArtemtrk, Nov 6, 2020.
  1. AArtemtrk
    AArtemtrk Light Load Member
    56
    59
    May 18, 2019
    I was wondering if anyone could help me diagnose a high temp warning light issue. The light and buzzer on my 3406b has come on a couple times however my fan did not kick in. I swapped this motor into a new truck and I took the temp gauge from the truck the motor came out of. The gauge only reads 200f when light and buzzer comes on, fan used to kick in around 205f when this motor was in the old truck. I’ve replaced the single wire sensor for the temp warning as well. My question is how can I narrow down if my buzzer is coming on early, or if the gauge is reading low? The sensor for the buzzer that I replaced is rated for 215f so there is definitely some kind of discrepancy.
    Thanks in Advance!
  3. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    On a B the fan should come on at 208f. Most gauges are out a bit, some as much as 10 degrees. Check the gauge against real temp by comparing the gauge to an IR thermometer reading at the thermostat housing. My last B was fueled up pretty good. 215-220 on long mountain pulls usually. The BSX I have now I think trips the fan at 213f but the gauge reads 205.
    AArtemtrk, Dale thompson and 650cat425 Thank this.
