Cat 3406b motor starts with ether but won't keep running
Discussion in 'Freightliner Forum' started by Rick Wilmath, Oct 19, 2018.
  1. Rick Wilmath
    Rick Wilmath Light Load Member
    57
    May 15, 2016
    I have a 1993 freightliner with a cat 3406b motor. I have been having problems starting it. It runs fine once it is started. If I loosened a couple of the fuel lines going to the head it would start but today it would not start even with ether. I replaced the hand pump that is on top of the fuel filter.
    Any ideas?
    Thanks
  3. wore out
    wore out Numbered Classic
    17,437
    217,123
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Check the inlet fitting on the bottom of transfer pump it is bad to come loose. Most times you have to grind an 11/16 wrench down thinner to get to the jam nut. Also check that the transfer pump is indeed working. If so you most likely are sucking air between the pump and tank. Though most times it will start then die when that is your trouble
    Grubby Thanks this.
  4. 22dragoo
    22dragoo Bobtail Member
    41
    50
    Nov 18, 2015
    Oklahoma City
