Cat 3406B oil leak problems
Discussion in 'Trucks [ Eighteen Wheelers ]' started by truckin-fool, Oct 30, 2020.
  1. truckin-fool
    truckin-fool Bobtail Member
    8
    Oct 29, 2020
    I have a 3406b with roughly 1,000,000 miles on it
    There is a massive leak from the injection pump as well as the oil pan it looks like
    does anyone have experience with these issues?
    How much would it roughly cost to repair these issues?
  3. jamespmack
  4. AModelCat
    165,156
    You're most likely going to have to clean all that gunk off first. Way easier to see what's leaking when its cleaned up.
    Dave_in_AZ, MACK E-6 and spsauerland Thank this.
  5. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    looks like its been leaking for that 1,000,000 miles pump needs sealed up
  6. truckin-fool
    8
    Oct 29, 2020
    what kinda cost am I looking at to seal it up?
    Im trying to figure out if its more cost effective to drop in a newer motor in instead of trying to fix this one with the miles it has on it
  7. SmallPackage
    5,818
    18,640
    Dec 20, 2019
    Marion Texas
    Five years ago I was getting parts for one of My Cummins PT pumps and the pump shop had a rebuilt mechanical 3406 pump painted and ready to install sitting on the shelf. It had a $2500 price tag on it. They said that was the price for a non core buyer. Much cheaper. Possibly half that if you swap rebuildable one for it or they rebuild yours and you get it back.
    650cat425 and AModelCat Thank this.
  8. MACK E-6
    50,173
    239,826
    Aren’t B model CATs pretty much notorious for oil leaks anyway?
  9. truckin-fool
    8
    Oct 29, 2020
    yes they are but I would like to have a nice clean engine
  10. wore out
    wore out Numbered Classic
    17,444
    217,347
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    No need to spend 2500 on a reman pump. For about 250 bucks you can reseal that whole govnor section on the truck. Put a 8M-9141 govnor spring in it, add an extra washer to spring pack. New weights, pins and races.
    On the bottom rail of the block just above the oil pan there are several plastic plugs with o rings that seal them. They often leak and the pan gets the blame.
  11. truckin-fool
    8
    Oct 29, 2020
    thank you for the information, thats great news now I need to find a reputable shop in Reno that can do the work lol
