Cat 3406B oil leak problems
Discussion in 'Trucks [ Eighteen Wheelers ]' started by truckin-fool, Oct 30, 2020.
  1. truckin-fool
    truckin-fool Bobtail Member
    8
    Oct 29, 2020
    @wore out how many hours should it take a shop to do this job?
  3. wore out
    wore out Numbered Classic
    17,451
    217,447
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Depends....on their experience level with a B. Governor section I'd say 5 to 6 hours. Oil pan and spacer plate 3.
    pushbroom and truckin-fool Thank this.
  4. Gambino1994
    Gambino1994 Light Load Member
    187
    103
    Jan 22, 2009
    causing a situation
    wore out what would your guess be for the gov spring in my 3zj 425@1900 rpm? I had the pump rebuilt 5 years ago when I bought the truck, how much would that 8m-9141 spring wake up this motor?
  5. wore out
    17,451
    217,447
    Jun 5, 2013
    It will make it pull all the way to 2100. Be sure to add the extra flat to the spring pack
    pushbroom and Gambino1994 Thank this.
