Cat 3406B peec engine won’t idle down while shifting
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by jsetzer90, Sep 18, 2020.
  1. jsetzer90
    jsetzer90 Bobtail Member
    Kind of stumped on what I have going on. while either upshifting or down shifting the engine will just hold rpm for awhile after you take your foot off the pedal which makes it very difficult to drive even if you try to double clutch. It will do the same if you just rev it while parked sometimes it takes 10+seconds to come down
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,551
    6,641
    Aug 26, 2014
    Check for air in the fuel to the injection pump.
    jsetzer90 Thanks this.
  4. jsetzer90
    I’ll check that when I get a chance. I don’t know what exactly has been done to it prior to me owning it but everything seems to be in good working order other than this issue. It did at one point hang right around 1500 for close to 30sec
  5. wore out
    wore out Numbered Classic
    17,344
    215,405
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I would look closely at the throttle position sensor and the rack sensor or BTM I believe they called it
    pushbroom Thanks this.
  6. ERICD012
    ERICD012 Bobtail Member
    Dirt on the fuel pedal
  7. Michael 247
    Michael 247 Heavy Load Member
    896
    4,718
    Nov 20, 2017
    Dublin Va
    My Big Cam Cummins done the same thing...I changed the Fuel Filter and it fixed it ..
  8. ultra truck
    ultra truck Bobtail Member
    17
    7
    Oct 21, 2020
    Deland Fl.
    Possible lost a governor spring if it is a 3406B
