Cat 3406e getting hot
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Nestor, Aug 3, 2020.
  1. Nestor
    Nestor Light Load Member
    160
    23
    Oct 21, 2015
    I was wondering if I can get some help please. I have a 3406e on a 96 kenworth w900 that gets pretty warm . When parked at idle for 5 10 min, my coolant temp starts rising pretty fast. Also when I hit a small hill it also starts climbing pretty fast and this is while empty . This happens with fan off. When I hit my fan, it cools it down really fast at idle and when I hit a small hill.
    I recently rebuild engine . New radiator and water pump. Before rebuild it was kinda doing same thing . Ended up rebuilding because I had 2 broken pistons. Throwing coolant tru overflow . I went from 190 to 180 to 170 thermostats . The 170 help a little but eventually will start rising . Any one have any clue why this is happening thank you
  3. zinita17601
    zinita17601 Road Train Member
    1,324
    1,613
    Aug 19, 2010
    lancaster pa
    Clogged oil cooler?
  4. p608
    p608 Road Train Member
    2,181
    2,993
    Nov 10, 2016
    thermostats, low coolant
  5. Inderjit
    Inderjit Heavy Load Member
    772
    738
    Sep 17, 2017
    The fan cools it down when switched on manual. Is the fan coming on automatic at 195 degrees?
  6. Nestor
    160
    23
    Oct 21, 2015
    Would a clogged oil cooler do it? My oil temp always around 150 170
  7. Nestor
    160
    23
    Oct 21, 2015
    Before I rebuilt it I had a sensor thermo sensor that was set 195. One of the tabs broke off on top so I replaced it but I got a 205 one . My fan doesn’t come on at 205 . But I’m turning on fan manually . I plumed in a external gauge that I bought for autozone right into thermostat housing . It reads like 15 20 degrees hotter than the one on my dash
  8. Inderjit
    772
    738
    Sep 17, 2017
    If the fan does not come on at 205 then that is your problem. if you short the terminals on the fan temp sensor together when the engine is idling the fan should engage. If it does the wiring is good and you need a new temp sensor.
  9. Nestor
    160
    23
    Oct 21, 2015
    Yea that’s what I was thinking . But temp climbs fast when at idle and when I’m loaded or empty going on a small hill .
  10. 062
    062 Road Train Member
    6,346
    34,009
    Oct 20, 2013
  11. p608
    2,181
    2,993
    Nov 10, 2016
    He said it's new
    062 Thanks this.
