Cat 6nz bad mpg
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ninehk, Oct 30, 2022.
  1. ninehk
    ninehk Bobtail Member
    20
    Jun 10, 2020
    Got a 2000 peterbilt 379 pulling reefer with a 6nz I got 4.3mpg from south Texas to Oklahoma and from Oklahoma to Missouri I got 5 mpg with wastegate pinched, is the wastegate itself possibly bad ?
  3. ninehk
    20
    Jun 10, 2020
    I would think so too but I was getting 5.0 to 5.4 mpg doing the same runs with non pinched wastegate getting 24psi boost and I’m at 33psi pinched
    Oxbow Thanks this.
  4. lester
    2,957
    8,087
    Jan 2, 2012
    NW, Iowa
    Why is the wastegate pinched? How much boost do you get with it pinched and how much without it pinched?
    If you are trying to get better mileage don't let your boost run up all the way.
    How fast are you running?
    Oxbow and Bean Jr. Thank this.
  5. lester
    2,957
    8,087
    Jan 2, 2012
    NW, Iowa
    Well then your wastegate is working
  6. ninehk
    20
    Jun 10, 2020
    I run 68-70mph keeping it at 1500rpm for the majority of the time
  7. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    What was the wind like? That #### eats mileage like nothing else.
  8. ninehk
    20
    Jun 10, 2020
    No real wind in between both fillups
  9. Diesel Dave
    9,737
    33,355
    Jan 20, 2010
    Hesperia, Ca.
    Probably has a Low-NOx file in it. Find a reputable tuner and also have the overhead adjusted.
    ninehk and Bean Jr. Thank this.
  10. AModelCat
    165,057
    Sounds standard for a Cat. Personally never seen one break 5 mpg.
    Oxbow Thanks this.
  11. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Really? I'm around 5.5 to 6 frequently as long as I'm not fighting wind too bad. Throw wind in the mix and it burns fuel like an aircraft carrier.
    Roger McG, Oxbow and RJM1953 Thank this.
