Got a 2001 peterbilt 379 with Cat 6nz.
The engine brakes just stopped working, in about a 30 minute time frame. Jakes were working perfectly fine then about 30 minutes later i turned the switch on to use them and nothing.
Cruise control and oil psi is good. Got no check engine light. No slack in the clutch. Completely stumped.
Tried checking if its a bad switch by jumping the plug with a small piece of wire.
Cant check solenoids or anything yet. Currently loaded and on the road
Anyone have an idea where to look ?
Cat 6NZ Engine brakes Not Working
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Kdub99, Jun 29, 2022.
If you have power at the switch and the switch is functional then pop the valve covers and look around the harness real good for any breaks in the insulation. Those harnesses are known for crapping out.
Should I check under a certain valve cover or all of em
All three of them. The harness connects to each injector solenoid as well as the jakes.
