Cat "blue goo" rust preventive.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by spsauerland, Oct 16, 2019.
  1. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Talking about the rust preventive that Cat reman puts on cylinder heads. I am positive that the guy who applies it goes home looking like a Smurf. Usually just clean it up with rags and electrical contact cleaner. Curious if anyone has actual Cat literature on it and the their cleaning procedure. Always assumed it was oil and fuel safe because they get it everywhere. Any feedback appreciated.
    pushbroom, ??? and Oxbow Thank this.
  3. AModelCat
    164,665
    We just toss them in our big hot water pressure wash cabinet for a few minutes. Rinse with clean water to remove the soap residue, blow dry and immediately soak it in WD40 to keep from rusting. Brake clean takes the WD40 off easy.
    pushbroom, spsauerland and Oxbow Thank this.
  4. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    This was pretty much the same procedure we use when I worked for caterpillar.
    spsauerland and AModelCat Thank this.
  5. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    Steam clean and blow dry is the best method I found. Gets a head from sticky to clean in short order. Cold just doesnt cut it either. Nasty stuff indeed. But I've never found any rust on anything coated with the stuff either.
    spsauerland, BoxCarKidd and pushbroom Thank this.
  6. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    I worried about getting around the valve seals and always had some blue goo left in places. Never had a problem.
    spsauerland Thanks this.
  7. Goodysnap
    3,771
    9,195
    Jul 12, 2017
    I have a fan tip and your not gonna get stripping paint close. I always blow out the ports thoroughly to be sure to get all the water off the top of the valves. After washing with hot water the residual after blow off almost evaporates. There is always some small crannies that get missed.
    BoxCarKidd and spsauerland Thank this.
