Cat BSX iva/injector harness replacement
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Cajuncowboy654, May 26, 2020.
  1. Cajuncowboy654
    Cajuncowboy654 Light Load Member
    138
    34
    Jun 4, 2019
    So I need to swap out my injector harness on my BS .
    What else do i need to buy other than the harnesses, which gaskets need to be replaced while doing the job.
    I know the valve cover seals are reusable, what about the gasket between the head and the framework that the wire harness is tied into? Is it a reusable seal or a gasket that needs to be replaced?
    Thanks
  3. Goodysnap
    Goodysnap Road Train Member
    3,782
    9,223
    Jul 12, 2017
    Square grey rope seal on the valve cover base to the head. RTV sealant at rope joint. I always replace valve cover gaskets unless I know the age. May need some 5/16 helicoils, too....
    Get the oil seals at the harness to base too.
    I would change all oil galley plug orings on the allen plugs in the base. They get hard and brittle. Jake or oil feed bridge o-rings as well.
    A5¢ and pushbroom Thank this.
