Cat c-12 engine mounts.
Discussion in 'Kenworth Forum' started by circle h, Jul 11, 2021.
  1. circle h
    circle h Light Load Member
    240
    375
    Oct 22, 2020
    Can anyone tell me how to replace the engine mounts on my c-12. It doesn't appear that I can jack the engine high enough to slide them in. Please correct me if I am wrong, or let me have any tips or tricks you might know. Thanks
  3. circle h
    240
    375
    Oct 22, 2020
    BTW. I forgot to mention this is in a 2004 w900b. Sorry.
  4. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Jack it up, they come out. I usually do them at clutch time if they are more than three years old.
  5. circle h
    240
    375
    Oct 22, 2020
    Thanks, I just went and looked again. I have a cross member directly over the ujoint at the back of the trans. That is what is causing it not to be able to go up. The front mounts are totally collapsed also so I will try them first. I'll let you know how it goes.
  6. AModelCat
    164,828
    Are you able to safely support the engine/transmission and unbolt the bracket from the frame rail? Might be a work around if you aren't able to get the engine lifted high enough.
    circle h and spsauerland Thank this.
  7. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    I usually get new bolts because they tend to stick/seize to the bushing liners.
    AModelCat and circle h Thank this.
  8. circle h
    240
    375
    Oct 22, 2020
    Thank you, I got it. The fronts were so far gone that I could not go high enough on the back. I did the fronts first, jacked up the back and they went right in. Rears were metal on metal.
    spsauerland and AModelCat Thank this.
