Cat C-15 6NZ starting issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Galves10, Feb 29, 2020.
  1. Galves10
    Galves10 Bobtail Member
    I’m having an issue with my c15 6nz engine.
    Engine only turns on when using starting fluid. Then after that if runs great, but if I turn it off and try turning it back on it will only crank but not start until I spray it with starting fluid again.
    could it be a sensor? And if you which one
  3. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Check valve in filter head. Takes a 1" wrench .
    Take out and replace with a new one.
    Don't mistake it for the pressure regulator as they look the same and take the same 1" wrench to take out
    spsauerland, SAR and pushbroom Thank this.
  4. Chubby Fly
    Chubby Fly Medium Load Member
    569
    797
    Nov 25, 2019
    possible causes. FUel regulator as mentioned, fuel primer bad diaghram, bad secondary housing, bad fuel pump not holding pressure and bleeding back to tank when truck shuts off.
