CAT C-15 Acert .... multiple problems??? HELP
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ltdcarriers, Dec 7, 2012.
  1. ltdcarriers
    ltdcarriers Bobtail Member
    11
    Hi, I have a 2005 Columbia carhauler with a CAT C15acert. This is my first CAT, just bought this truck in June 2012. Since: First week I had it it blew a radiator hose, had that replaced. 3 months later Cracked #6 liner was pushing pressure into coolant sytem..resulting in a Gold kit install at Cleveland Bros in PA. Ran ok after that, for 10K miles. Then while driving last week on a cool day water temp spiked to 250, I shut it off and got towed to a CAT dealer, diagnosed with a sheared off impeller on water pump..result, replaced water pump..ran ok for 600 miles, while loaded climbing a grade I noticed a vibration, my first thought was the driveshft u joint bolts werent tightened after the tow. Pulled off, looked around, then noticed the engine was still shaking/vibrating in idle. Went to TAG truck repair in Jackson, TN found a broken (clean off)#2 injector rocker, fortunately it didnt damage the cam or the injector...had that repaired went on to Memphis, back to Nashville, up to Clarksville then back to Smyrna to reload and stayed the night in cookeville, tn (approx 44o miles later) I could smell coolant when I got out to stretch, so I took a look....coolant stains on top of the engine.. I assumed it was left after the injector rocker repair and didnt get cleaned. ( I told you this is my first CAT ). I kept an eye on coolant level and the coolant stains on the engine...the stain/wet areas got larger and larger, like I drove through a cooalnt rainstorm, but its not using alot of coolant.. i kept topping it off to be safe until I could get the load off and get back to my homebase. I made it, gauge never showed it get hot, or cold, stayed right around 190. I hear a "slapping or tapping" sound at irregular intervals, sounds to me like a thermostat, but I am no diesel (cat) expert. I can also hear from inside the cab a drony hum as if the water is pushing through the surge tank cap, but when I check the water and top off there is very little pressure in the tank, as i loosen the cap there is a slight hiss then i can top off. I called my shop on my way home and explained all this...They said that it is possible to cut a 1/4" hose when doing the #2 injector and it can make this kind of a mess. I cant find a 1/4" hose anywhere around the top of the engine..Still looking, going to do a cooling system pressure check later today.
    My question is with all these coolant system related issues am I missing something larger? Cleveland Bros inspected the head, and stated it didnt have any cracks. The engine seems to run fine but I am losing my confidence in this thing. I ve been loaded every time there is a problem, I haul new cars and dealerships get ugly if they are a day late. I ve been a week late twice. Are these random 500K mile problems or did I buy an albatross?
    Is there some type of diagnosis/checkup I should have done? I just started using a CAT dealer in my town as my regular mechanic. I need to know what to ask them to do for me. maybe a match and some gasoline? I am worn out mentally and financially with this truck already. Please give me some real advice.(hope). Thanks
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    1/4 hose they are talking about is probably the overflow hose on your surge tank. quit toping it off if you fill it all the way up it will push the extra coolant out until it gets down to the right level. water level should be about 1 to 2 inches below fillercap neck.
  4. ltdcarriers
    11
    The overflow hose runs down the back of the surgetank, nowhere near the #2 injector/cylinder head cover. It was not doing this before that repair so I dont feel it is an overfilling issue. Thanks
  5. Largecar359
    Largecar359 Road Train Member
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    Super hauler is right if you keep putting coolant in its gonna keep pushing it back out till the level that the truck likes to run at is reached. My c-15 runs approx 3 inches down. My 3406b runs a little further down. How bad is the slapping/tapping?
  6. underpsi
    underpsi Road Train Member
    1,266
    292
    Sep 18, 2008
    Toronto, Ont
    Where are you finding the coolant stains? On the top of the valve covers?
  7. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    Which side of the engine also.
  8. JohnP3
    JohnP3 Road Train Member
    1,594
    684
    Feb 21, 2010
    Rock Creek B.C. Canada
    I would have the Rad cap checked, and the cooling system checked when cold looking for a leak at a clamp or hose connection.
    The rest is normal for a Cat, Normally when one rocker arm is broken we would check with Cat and get the OK to do them all, even if out of warrenty period they would usually cover the parts.
    One thing is certain, if you do not ask you will not get.
    There is a mark on the surge tank that is the full mark when the engine is cold. do not over fill or under fill.
  9. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,041
    Dec 17, 2008
    There is a 1/4 " hose that goes from the thermostat housing to the expansion tank. It is used as a bypass hose to keep the water pump from captivating when the thermostats are closed. This hose will be located on the right side of the engine, at the front of the engine close to the valve cover spacer placte. If it is blocked or pinched off it will cause funny things to happen. It could also have a lose clamp allowing it to leak everywhere around the top of the engine
  10. Gear head
    Gear head Medium Load Member
    532
    91
    Apr 1, 2012
    Belair,md
    There is an inexpensive coolant system tester you can buy from napa and probably alot of other local automotive stores. It has blue fluid that goes in the tester that goes where the rad cap went. If the fluid changes from blue to green you have exhaust gases in coolant system. The test kit will descibe the process in full.
  11. ltdcarriers
    11
    Im sorry I didnt post the answer to the mystery sooner, truck has been wearing me out with nickel and dimers. This problem was the radiator. 700 bucks.
