I have only looked at two & the tags were on the upper center, left side of motor. Plenty of CAT guys that will definitely correct me if I am wrong.Should be a BXS or MXS pending year of motor.
CAT C-15 engine problems
Discussion in 'Trucks [ Eighteen Wheelers ]' started by warn, Jan 26, 2010.
Page 2 of 5
Mine is an 06 W9 with an 05 engine. Serial # starts with MXS.It is found on left upperside of engine.And yes yours should be an Acert.rookietrucker Thanks this.
hi guys, i have a problem, if somebody can help me.
i bought a cat c15 acert engine, the engine was installed ina peterbilt 2010, but, i want to put the engine in a kenworth T800 2007, but the harness that goes from ecm to cab doesnt match, they're diferent, i'm from mexico and i dont know wher can i find it, if you know what is, please reply, my truck is trunk because that
can you tell me the number of part or how can i ask for it -
I believe Cat makes a harness for this, I'm sure someone on here will direct you in the right direction.
What did you do to get better fuel mileage? I have a 06 W900 and the best I can get is around 5.5
need more details please! i have a 06 accert, replced head at 301000kms(188200miles approx.)lucky was warrenty for parts and labor(i bought it at auction and had 297000kms/185625miles) two weeks later replaced wiring harness in head(warrenty after getting upset with cat) had top end reset after putting 160000/100000miles on it. It runs smoother but fuel milage is poor 3.8-4.5mpg pulling 8axle grossing 140000lbs !!!!!
ps! cat nip like to know what you did to get fuel milage up?
I havent heard of anyone converting a DPF Cat backwards to an 07. maybe your trying a direct swap.cant tell by your post. Im pretty sure anything with a DPF had to have cab/chassis mods to make everything fit and your 07 wont have that. give more details
2006 C-15 550 what will i have to change to go 625!
the exhaust system is diferent between sdp and my old kenworth engine, somebody told me that i need to rewire the harness, but it is too dificult, i have been searching in the internet but i cant find the one that i need, i have a question, every kenworth harness of sdp engine is the same? any year 06,07,08,09,10?
Page 2 of 5
Should be a BXS or MXS pending year of motor.![[IMG]](proxy.php?image=http%3A%2F%2Fimg31.imageshack.us%2Fimg31%2F5971%2Fmxsserialcode.jpg&hash=9f13037ad609d716dba07d5df605b35b)
