Cat C-15 fuel question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Largecar359, May 15, 2021.
  1. Largecar359
    Largecar359 Road Train Member
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    I recently updated one of my 359’s with a C-15 motor. I removed the original 3406b, and replaced it with a C-15 6NZ. In my B motor I always ran lubricant in the fuel to compensate for the lost lubricant in today’s fuel compared to the fuel refined back in 1985. Is this something I should continue to do with the newer style motor? I was planning on only using a fraction of what I used to put in the fuel, does this seem correct? I understand fuel supplements are a controversial issue, with that being said, the 3406b turned a hair over 3 million miles before coming out. Is the C-15 a motor that likes a small amount of lubricant for injectors?
  3. lester
    2,957
    8,089
    Jan 2, 2012
    NW, Iowa
    I think everything can benefit from a little additive. This fuel is so dry, adding some lubrication is good.
    My john deere dealer strongly recommends all its customers to run something in all their equipment
    Coffey Thanks this.
  4. Largecar359
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    Well that is my thinking, diesel fuel today is far too dry and almost evaporates when rubbing it with your fingers. I remember when you would have to watch your step on the fuel rack bc if you got diesel on your shoes it was a major hassle to get it off. Don’t seem to have that issue anymore.
    I just wanted to ask some guys/gals that have the C-15 what they have been doing.
  5. 062
    062 Road Train Member
    6,351
    34,022
    Oct 20, 2013
    I have a E-model and dump a gallon of two stroke to 300 gal when I can remember to do it. I wouldn’t try it with these new motors and the stupid high fuel psi.
  6. rollin coal
    rollin coal Road Train Member
    13,703
    28,201
    Mar 29, 2008
    TN
    Count me in the skeptical category. I never ran any fuel additives through the MBN C-15 my other truck had. The odometer showed over 1,500,000 miles when I got rid of it and more half of them were mine. No fuel related problems ever.
