cat c-15 mxs
Discussion in 'Trucks [ Eighteen Wheelers ]' started by oneloadshort, Apr 25, 2014.
  1. oneloadshort
    oneloadshort Bobtail Member
    22
    4
    Apr 27, 2012
    Houston TeXaS
    bought a 2006 t2000 with a c15 mxs 435 to pull containers,i don't know whats been done to it as far as mods and judging from the fuel filters yes im finding out i bought someone else's problems, question is is that the fuel filters that were on it were the cheap luber finer, dont remember the part # for the secondary, switched it out for a cat filter ran fine for around 5k, so before doing a little research, i replaced the LFF5 on the primary still runs like crap,i would like to go with a different primary but not sure which to use, i had a friend go to get a primary fuel filter for my motor because i was running and couldnt get to cat house and they gave him a element 9m-2342 for the case as fuel filter, well $230 to swap out to that set up is just to much at this time, i keep reading cat filters (what do i run for the primary water separator) is the way to go and then fs 1212 works well for some, i just would like more than 4.5 mpgs loaded and good god the lobbing of the motor likes its starving to stop, the second problem im also having is the speedo started jumping anywhere from 5-15mph with no change in speed since the filters started giving me problems....thanks in advance for any input
  3. wore out
    wore out Numbered Classic
    17,329
    215,214
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    The fs1212 is the water sep we have the most luck with. I like to use CAT final filters. For better MPG I would start with a good tune up. Get the engine running right first the rest will follow. There is an amazing difference in one that runs pretty good and one that is right. Setting the valves and injectors, checking to make sure there are no charge air leaks, checking fuel pressure as well as making sure its not got air in the rail is a good start.
    oneloadshort Thanks this.
  4. russtrucker
    russtrucker Road Train Member
    1,767
    337
    Mar 27, 2012
    Central PA
    CAT filters is the best I can recommend. could be better if i add fass.
  5. jameslawton
    jameslawton Light Load Member
    257
    65
    May 1, 2013
    Tulsa OK
    Cat filters have a better filter usually down to 2 microns if you use two cat filters can starve the engine using a cheaper water separator at like a 10-15 microns will help and on the Speedo bounce the yoke nut on the granny is probably loose causing that
  6. oneloadshort
    22
    4
    Apr 27, 2012
    Houston TeXaS
    Well a tune up, overhead may be in order....whats the going rate for that, or better any recommend shops in around Houston, I had I guy look at it, he owns seven trucks does his own work, he stuck his had on my blowby tube had me rev the motor up then took he's hand off after I shut it down, lots of air blowing back, he seems to think its my rings,but I'm losing no oil or gaining any for that matter,the other problem I have is he owns 7 trucks and my be trying to get me to get the work done to put me in one of his trucks,paranoid perhaps....staying tuned....
  7. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    Take it to a Cat dealer, have them run the overhead on it, it will probably cost you around $300.
    oneloadshort and wore out Thank this.
