Cat c12 fuel problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by raferko, May 9, 2019.
  1. raferko
    raferko Bobtail Member
    22
    6
    Oct 23, 2018
    Japan
    okay so I have a c12 with a fuel problem, it runs rough/sounds like it has a miss almost and is low on power, the fuel filter and water separator are new. I’ve replaced the filter housing as well so it rules out the regulator in there, the transfer pump has also been replaced and the fuel is clean, I’m stumped. Am I missing something here, is there another check valve somewhere on the head/fuel rail. Also at idle and high idle which is 1500 rpms I’m getting 40-no more than 50 psi of fuel pressure and it moves around in that range a lot like jumps around, and when I hear the engine slightly bog down is when it hits 40, finally there are no codes of any sort in CAT ET and all the injector solenoids tested out good and I also did a cylinder cutout test, any help would be appreciated.
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,889
    May 31, 2010
    West Harrison, In
    Do you have a fuel restriction gauge?
  4. raferko
    22
    6
    Oct 23, 2018
    Japan
    No?¿
  5. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    From what I've heard about C12 CAT engines is they can go bad in many ways. Rebuild them and 1 week later they are scrap.
    The worst CAT engine ever, and replace it with a C13, I hear often.
  6. spsauerland
    4,296
    10,889
    May 31, 2010
    West Harrison, In
    Pretty bad advice.
    Magoo1968, A5¢ and wore out Thank this.
  7. spsauerland
    4,296
    10,889
    May 31, 2010
    West Harrison, In
    To make fuel pressure, you need fuel. Need to plumb in a sight glass to see if you are sucking air and how old are your suction and return hoses? Could have a collapsing or restricted hose.
    wore out, Diesel Dave and swaan Thank this.
  8. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    More truck stop coffee counter B.S.!
    A5¢, wore out and Intothesunset Thank this.
  9. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    I'm with the sucking air or restriction idea as well.
    spsauerland Thanks this.
  10. Intothesunset
    2,289
    4,880
    Apr 15, 2019
    truck
    Is C12, or C13 the problem child? I may have gotten it backwards.
    Or it's just bad advice on all accounts, and C12, and C13 are both reliable engines?
  11. wtokhi
    wtokhi Light Load Member
    251
    115
    Nov 3, 2017
    Idk where
    idk where u get ur info from but c12s are one of the best engines, we have one in our fleet that has been running since 2009 after a rebuild with no problems at all since
    Canary379 and Intothesunset Thank this.
