Cat C12 has mechanics puzzled ..
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by TxBossMan, Oct 17, 2022.
  1. TxBossMan
    TxBossMan Bobtail Member
    18
    14
    Jan 31, 2014
    Sweetwater, Texas
    Need some help here ..
    Cat C12 (2KS)
    Red Shut Down Light - Low Oil Pressure
    Decent amount of Blow By and water dripping from blow by tube.
    Drained oil pan.
    Pressure up on coolant system. 18lbs for an hour and a half. No change. No Leaks.
    Pulled valve cover and there’s traces of water, not coolant, water like condensation. Evidence of rusting on Jake’s.
    1 mechanic says to change water pump.
    1 mechanic is still looking in to it because he doesn’t think it’s water pump.
    Advice and ideas??
  3. AModelCat
    164,782
    Well I'd start by investigating the low oil pressure issue before anything else.
    As for condensation, I'd say it needs to be put to work. When they're hot the water boils off and evaporates.
    D.Tibbitt, bzinger, Dino soar and 5 others Thank this.
  4. Cattleman84
    Cattleman84 Road Train Member
    10,018
    71,539
    Nov 1, 2017
    The Sticks, Idaho
    Yeah sounds like it been sitting in a field for several months... Or years.
    MartinFromBC Thanks this.
  5. TxBossMan
    18
    14
    Jan 31, 2014
    Sweetwater, Texas
    Run the truck everyday. It was running great, no problems. Pre-Tripped it. On my way to get fuel the Red Shut Down Light came on. Let off the throttle and when the rpm’s came down the red light went off and I got throttle back but lost it again when rpm’s came up and Red light came back.
    Hooked up my scanner and it doesn’t read any faults until Red Light comes on and it says Low Oil Pressure.
  6. TxBossMan
    18
    14
    Jan 31, 2014
    Sweetwater, Texas
  7. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    This exact thing happened on a buddy of mine with the same engine on a 97 Peterbilt 379.
    Changed out the oil pressure sending unit, water pump and the thermostat.
    Also ran the overhead as the valves were way out of adjustment, Now he says it runs like a top
    okiedokie, Cattleman84 and TxBossMan Thank this.
  8. TxBossMan
    18
    14
    Jan 31, 2014
    Sweetwater, Texas
    Thank you. I’ll pass along the info.
    Cattleman84 Thanks this.
  9. Magoo1968
    Magoo1968 Road Train Member
    2,056
    5,478
    Mar 18, 2021
    St Malo mb
    I may be mistaken but on some c12’s I believe if water pump starts seeping it does so from the backside into the oil.. is oil milky??
    singlescrewshaker Thanks this.
  10. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Send off a oil sample when you change the water pump and the oil and filter, just to be sure it didn't hurt the bearings?
    Magoo1968 Thanks this.
  11. TxBossMan
    18
    14
    Jan 31, 2014
    Sweetwater, Texas
    The oil is not milky. There was no coolant in the pan out on the dipstick. But there was a small trace of milky on the cap of the oil fill tube like condensation/steam buildup.
