Cat C12 sometimes not starting when I press START
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ichudov, Feb 24, 2019.
  1. ichudov
    ichudov Heavy Load Member
    742
    642
    Mar 14, 2012
    Berkeley, IL
    So I have this Freightliner FLD with Cat C12. I noticed that occasionally, I would press the START button when intending to start it, I would hear and feel a CLICK, and the starter would not engage. The starting relay is almost new. Would you say that it is a starter problem, like with starting solenoid and the copper ring that closes the starting circuit??
  3. McMahons Trucking
    McMahons Trucking Light Load Member
    274
    119
    Jul 4, 2018
    Check all your connection including the grounds.
    ichudov Thanks this.
  4. kemosabi49
    11,027
    48,170
    Jan 13, 2013
    SW Arkansas
    Are all of your connections clean and tight going to the starter?
  5. ichudov
    742
    642
    Mar 14, 2012
    Berkeley, IL
    Thanks guys. I will attach some temporary wires to the starter's terminal to watch voltage when starting up. I will follow up on this.
  6. ichudov
    742
    642
    Mar 14, 2012
    Berkeley, IL
    Is the engine block the ground for the starter, do you know?
  7. raferko
    raferko Bobtail Member
    22
    6
    Oct 23, 2018
    Japan
    The click you are hearing is the solenoid working, check the small wire on the large positive stud, should be a somewhat thin wire with a large connector since it attaches to the positive stud, 90% that, 10% your starter is actually bad, cross a wire or screwdriver from the positive on the starter to the smaller positive on the solenoid while the truck is in run and see if she starts, basically just doing a bench test....except in the truck, wayyy easier troubleshooting
  8. Deere hunter
    2,188
    10,742
    Aug 5, 2017
    Shallowater Texas
    Depending on the truck
    from your start button it should go to the solenoid on the fire wall and then from the solenoid on the fire wall to the solenoid on the starter sometimes in the wiring harness an older truck you need to run a new wire from your solenoid on your firewall to your solenoid on your starter is usually cures your problem
  9. ichudov
    742
    642
    Mar 14, 2012
    Berkeley, IL
    Thanks, is that because the wire from starting relay to the solenoid is damaged due to age? Is that what your thinking is?
  10. Deere hunter
    2,188
    10,742
    Aug 5, 2017
    Shallowater Texas
    That original wire goes through the wiring harness and it’s hard to track it down and less you just put a whole new wiring harness ,but every time I’ve done the new wire it’s fixed it !
  11. Deere hunter
    2,188
    10,742
    Aug 5, 2017
    Shallowater Texas
    To really answer your question yes age and corrosion but I don’t know the age of your truck !
