Cat c13 ecm replace issue
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Garry Sahota, Jul 14, 2020.
  1. Garry Sahota
    Garry Sahota Bobtail Member
    37
    4
    Oct 6, 2015
    Brampton, Canada
    Hello guys
    my cat c13 KCB 2007 ecm got bad. I ended up replacing it with same series engine ecm from Kenworth (same year as mine Kenworth)
    I didn’t get it reprogramed , my engine now goes at 65mph at 1300 rpm before it goes at 1400 rpm.
    my question is should i reprogram it from cat or leave it as it is , i have no other issues, everuthing is working.
    only thing i feel is less rpm makes it little hard to pull hills.
    thanks
  3. pushbroom
    pushbroom Road Train Member
    1,788
    7,397
    Sep 1, 2012
    All it is is a simple parameter change. Should be able to get it done in under a half hour easy
  4. Garry Sahota
    37
    4
    Oct 6, 2015
    Brampton, Canada
    Cat is asking $400 to reprogram whole ecm to my vin. I am curious like if i leave it like as it now (low rpms) is that any problem to engine or any other issues?
  5. gerardo1961
    gerardo1961 Road Train Member
    1,751
    618
    Feb 21, 2010
    Miami
    When i change my ecm for my c 13 kcb was with reprogram never have a problem now 1501000 milles without rebuild
  6. AModelCat
    164,688
    Your engine isn't running at a lower RPM. Your tach is getting the wrong info from the ECM due to wrong parameters being programmed into the ECM.
    As for negative long term effects, could be possible.
    Garry Sahota and magoo68 Thank this.
  7. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Check your speed against a gps I’d guess your only doing 60 or61 instead of 65 until you change tire or gear settings in ecm
    Garry Sahota and AModelCat Thank this.
