Cat C15 Fuel Problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Brightlog, Jun 12, 2019.
  1. Muddydog79
    Muddydog79 Heavy Load Member
    820
    2,147
    Apr 14, 2016
    Ive seen several different mbns and none have had the hand primer. Why idk.
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,731
    Jan 30, 2010
    keep stroking.
    Unusual mbn is a 6nz basicly. You sure there isn't a primer plunger on top of filter housing ?
    Oxbow Thanks this.
  4. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    return hose can have a leak and wont cause starting issue. It just goes to tank. You can check for leaks in all your lines by threading in an air fitting to the top of the tank. preussreize the tank with no more than 1 or 2 psi and if there is a leak ANYWHERE, you find a steady drip which will be easily seen.
  5. Cam Roberts
    1,621
    1,938
    May 13, 2018
    Not all cats have hand primer but some of them do. Depends on what you ordered. Most install them afterward. So you cant say mbn doesn not have one. some 6nz have them and some dont. There are plenty mbns with them. The op will clearly be able to see if he has one or not. If it does not have one and there is a block off plate where there would be a hand primer. My suggestion would be to remove the block off plate and install hand primer. I had an issue with block off plate where truck wouldnt start. Installed hand primer and havent had a problem in 2 years. Something about the check valves in the primer which are very good.
  6. Muddydog79
    820
    2,147
    Apr 14, 2016
    Yes im positive.
  7. Muddydog79
    820
    2,147
    Apr 14, 2016
    sorry, your right! It was the supply line. Guess my long term memory loss is catching up to my short term:scratch:
  8. Superhauler
    12,209
    100,731
    Jan 30, 2010
    keep stroking.
    Ok, then after you check all your lines and they check ok. The only thing left is injectors. You can have an injector leak off when the engine is not running and operate normally when running. Then it takes the transfer pump a while to build up enough pressure for the injectors to fire.
  9. Muddydog79
    820
    2,147
    Apr 14, 2016
    I was just saying mbns do not come factory with a hand primer is all. I know you can easily add one.
  10. Muddydog79
    820
    2,147
    Apr 14, 2016
    Yes i agree. Hopefully the op will get these messages lol.
  11. Cam Roberts
    1,621
    1,938
    May 13, 2018
    oh ok buddy. Wasnt sure. so i was just following up
    Muddydog79 Thanks this.
