Cat C15 loses power, white smoke from exhaust
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ichudov, May 31, 2023.
  1. ichudov
    ichudov Heavy Load Member
    742
    642
    Mar 14, 2012
    Berkeley, IL
    I have a 2005 Peterbilt with a Cat C15 (is it ACERT? - no emission equipment) It has a twin turbo.
    Yesterday, after delivering a load and on the way back empty, I noticed the truck started losing power and could not even go 60 MPH with an empty gondola trailer.
    The truck and engine would also shake as it was lacking power and emitted white smoke from the exhaust.
    As I kept driving it became worse, and I could not go faster than 15 MPH. Fortunately, at this point, I was only 5 miles away from my place. I had to unhook my trailer and go home, bobtail and picked up the trailer with another truck.
    We investigated this today. We can reproduce it by going bobtail to about 5th gear, then if I push the gas pedal hard, it loses power, the engine shakes, and the truck cannot accelerate.
    There is NO coolant loss, and the white smoke smells like diesel. The check engine light does NOT light up.
    Any idea what it could be?
    Thanks!
  3. AModelCat
    166,497
    Sounds like a failed injector, maybe a broken rocker arm.
    lester Thanks this.
  4. ichudov
    742
    642
    Mar 14, 2012
    Berkeley, IL
    Thanks. Would this "failed injector" problem show up only when a lot of power is asked for? The engine runs nicely at idle; the problems only show up when I push the gas pedal to demand more power.
    Is there something I can do to pinpoint this problem? Open engine covers? thanks!
  5. AModelCat
    166,497
    Shouldn't be a huge deal to open the valve covers and take a look. If nothing wrong there then run an injector cutout test with ET.
  6. SSDD
    SSDD Bobtail Member
    Jul 30, 2020
    Have you tried changing the fuel filters?
    Opendeckin and pup Thank this.
  7. gekko1323
    gekko1323 Road Train Member
    1,700
    2,839
    Jul 14, 2018
    Henderson, NV
    Did you find the cause of your problem? My truck is doing the exact same thing. But she "belches" the smoke. I'll be doing 65 mph let's say, she rumbles and shakes, slows down, belches white smoke, then feels a lot better and takes off. Sometimes she won't do this for weeks. Other times, she'll do it 10 times a day.
  8. alamaslat
    alamaslat Bobtail Member
    I have the same problem and can’t seem to figure it out…. Did you ever figure it out?
  9. ichudov
    742
    642
    Mar 14, 2012
    Berkeley, IL
    Yes, clogged fuel filter (due to bacteria in the tank)
