Cat c15 MBN
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Kw Owners Club, Feb 5, 2020.
  1. Kw Owners Club
    Kw Owners Club Bobtail Member
    42
    22
    Jan 1, 2019
    2003 cat c15 single turbo MBN 475hp in a Peterbilt.new turbo ,flow through mufflers.It smokes black when under load constantly,not just a small puff when upshifting but a steady stream of smoke,also just had a valve set done and air and feul filters so all that is outta the way and made no difference......worn injectors ??
  3. lester
    2,956
    8,078
    Jan 2, 2012
    NW, Iowa
    Major boost leak? How much boost pressure are you building?
  4. Mattmanstroked
    Mattmanstroked Light Load Member
    185
    279
    Nov 24, 2019
    Did this start after replacing turbo?
  5. Kw Owners Club
    42
    22
    Jan 1, 2019
    Boost is great almost 40psi it's actually done it for a long time it's just strange to me that it would smoke constantly,runs perfect otherwise
  6. anthonyar4
    anthonyar4 Medium Load Member
    431
    92
    Jun 8, 2019
    Hmm. Only thing I can think is a sensor issue or rebuild time? Possibly a sensor like the air flow is reading incorrect and not throwing a code. I have a MBN and it only smoked on shifts.
    Kw Owners Club Thanks this.
  7. anthonyar4
    431
    92
    Jun 8, 2019
    Check your oil. Had a guy on the road I helped out that probably blew his turbo and was sending all his oil right out the exhaust pulled his dipstick and bone dry.
  8. anthonyar4
    431
    92
    Jun 8, 2019
    Obv you’re isn’t blown but could be sending your oil out the exhaust. Check exh tips for oil residue. Intake or exhaust valves stuck or out of adjustment or plain jacked up.
  9. anthonyar4
    431
    92
    Jun 8, 2019
  10. Mattmanstroked
    185
    279
    Nov 24, 2019
    I was thinking he was black smoking which is unburnt fuel.
    Is the engine running the factory program or something else?
  11. 062
    062 Road Train Member
    6,327
    33,966
    Oct 20, 2013
    I believe there is a boost sensor mod that fools the ecm into over fueling. @Superhauler can probably tell you where and what to look for.
