CAT C15 Problem Need Help ASAP
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Adamali21, Apr 20, 2022.
  1. Adamali21
    Adamali21 Light Load Member
    278
    180
    Jul 24, 2018
    Yup doesn’t look so good, my brother is heading over here bobtail pick up my trailer and I will leave with him and come back with a fifth wheel tow boom and take my truck back home.
    LameMule Thanks this.
  3. 062
    062 Road Train Member
    6,344
    34,002
    Oct 20, 2013
    Does the motor have a skip?
    It sounds like a galled or cracked piston. If it is that’s a fairly big job.
    LameMule and Adamali21 Thank this.
  4. AModelCat
    165,006
    Is it below freezing where you are? Have seen the vent tube freeze up and the dipstick blows out since its the easiest spot for the pressure to escape.
    Oxbow, D.Tibbitt and Adamali21 Thank this.
  5. AModelCat
    165,006
    Hole blown in a piston the vent pipe should be able to handle that without popping the dipstick.
  6. Adamali21
    278
    180
    Jul 24, 2018
  7. AModelCat
    165,006
    Eeek!
    White smoke, did it smell sweet or like raw diesel?
  8. Adamali21
    278
    180
    Jul 24, 2018
    I mean smells like burn oil.
  9. Adamali21
    278
    180
    Jul 24, 2018
    Can I turbo cause allot of blowby, Oil shooting from dipstick and exhaust and heavy white smoke. So heavy white smoke from exhaust, blowby, dipstick. And oil shooting from dipstick, exhaust and blowby.
  10. AModelCat
    165,006
    Sounds like it could be a little deeper than that. Going to have to start digging in a bit. Maybe yank the turbo and see if oil is coming out of a cylinder? If its wet in the manifold, might have to pull the manifold and isolate it to a cylinder.
    spsauerland Thanks this.
  11. Adamali21
    278
    180
    Jul 24, 2018
    Just ordered a new head and overhaul kit.
    What I am confused about is my ecm is reading a different serial engine number then what my engine really is. Back in 2018 this engine had a platinum overhaul. I have all receipts and called the dealer to confirm, a new ecm was put in by the dealer new. But why would the serial numbers be different unless someone flashed it.
    Oxbow Thanks this.
