Cat high exhaust temp.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by kelboy1971, May 31, 2014.
  1. kelboy1971
    kelboy1971 Bobtail Member
    22
    8
    Mar 31, 2014
    Hi guys, I have a 2000 International with the Cat c15, it doesn't take much of a hill and the exhaust temp gauge will go up to 1200, as soon as I back off and drop a gear it goes right down to around 300-400. What should I look for or is this normal for this engine? Thanks
  3. Derailed
    Derailed Road Train Member
    2,383
    2,657
    Dec 10, 2008
    Upstate NY
    I would say normal. Pulling an empty faltbed with mine it doesnt take long for it to get up around there on a hill, as long as your not keeping it there for long periods of time you should be fine.
  4. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,116
    May 19, 2011
    I don't think that's normal, usually when EGT's run high like that, there is a boost leak somewhere
  5. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    first check for a air intake leak, cac or a turbo boot. then pull the pipe off the turbo intake and look at the fins on turbo wheel. see if you can move it with your hand and put a little side pressure on it to see if it will rub the housing. those don't cost anything to check. another thing to try is set idle at about 1500 to 1700 rpm and squirt windex or soapy water on all the piping to see if it bubbles up if any bubbles that is a leak. you will only be making about 1 or 2 lbs of boost but it will be enough to find a leak, now think how bad that leak would be at 28lbs of boost or more. oh and squirt the elbow that comes off the turbo housing. those two O-rings have a tendency to leak also causing loss of boost.
  6. Superhauler
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    oh almost forgot the cac you may have to pressurize to see if it is leaking. to much surface area to squirt with the bottle. has the air filters been replaced? just some ideas to try.
  7. Derailed
    2,383
    2,657
    Dec 10, 2008
    Upstate NY
    What rpm range are you pulling the hills at when this happens?
  8. kelboy1971
    22
    8
    Mar 31, 2014
    between 1300 and 1500 rpm on hills usually.
  9. Derailed
    2,383
    2,657
    Dec 10, 2008
    Upstate NY
    Some guys say Cats like to be lugged down. I have an 01 c15 (6nz) and I noticed that the temps do creep up even when empty if you pull much below 1500 for awhile say with the cruise on. The guy who owned the truck before me said the same thing. 1500 on up temp is fine.
  10. Oscar the KW
    12,246
    28,116
    May 19, 2011
    When I'm pulling a hill with mine I keep it between 1500-1600 on a long grade with the fan on, pyro has yet to go over 900 doing that, below that it will get up to 1000, but I have never pushed to see how high it will go.
    tommygun58 Thanks this.
  11. 04 LowMax
    04 LowMax Medium Load Member
    440
    250
    Feb 3, 2013
    Alberta
    Yep. Well, almost, I have to actually get up to 1800-1900 in order to get the next gear, if outside temp is, oh, say 75 F or warmer. Having a C15 mbn which is now a 1mm, I have to drive it totally different, just like an old 80's truck. And, when up shifting, never even think about the next higher gear til the egts are back down to 810 or so, or there is no use, she'll be over 900 headed to 1000 in no time. Took a bit of getting used to this, but, really, for pulling 140,000 lbs, lots of power, and it actually sounds a lot better pulling at 1600 than it used to at 1350. So, to op certainly check out the things as suggested, but, it there may not be anything wrong, depending on what your pulling, etc.
