Cat MBN INFO PLZ
Discussion in 'Ask An Owner Operator' started by Rame, Jun 19, 2019.
  1. Rame
    Rame Bobtail Member
    17
    Jun 13, 2019
    Hello everyone I need some advice regarding 2012 pete 388 Glidder kit with Cat C15 MBN13479 475hp wheel base 244 ratio 3:55. Truck is in good condition . Motor has 700000 kms and truck has 1781990 kms. I looking to buy it please give some info regarding motor and your opinion. I will be so thankful.
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Why would someone put a MBN motor in a glider?
    Rame Thanks this.
  4. Rame
    Rame Bobtail Member
    17
    Jun 13, 2019
    No Idea ... this is what I get !!! I kknow about motor like 6nz mxz etc but no idea about it
  5. tnevin225
    1,166
    1,601
    Jan 1, 2014
    You might want to research that engine, was one of the worst motors Cat ever made, thats why I can understand why anyone would put one in a glider.
    Rame Thanks this.
  6. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Fairly easy to convert to 6NZ and has been discussed on this site.
    Rame, rollin coal and magoo68 Thank this.
  7. tnevin225
    1,166
    1,601
    Jan 1, 2014
    You might as well just take it out and replace it for what that would cost. And there are a lot of differences between them.
    Rame Thanks this.
  8. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Hmm it’s just a flash away from a 6nz other than a minor compression bump which is no big deal.. maybe your thinking of a accert sdp
    Rame, rollin coal and spsauerland Thank this.
  9. rollin coal
    rollin coal Road Train Member
    13,463
    27,464
    Mar 29, 2008
    TN
    Yeah dont give out bad advice. The MBN is a very good motor with a few upgrades. In stock form not so much so but like these drivers say easy to fix. I ran one for 10 years and it only had an aftermarket exhaust manifold, turbo and 6NZ flash and it was just as good as any factory 6NZ out there without having the same 6NZ camshaft, pistons and injectors. Very doubtful what is in this glider kit is a stock MBN it's probably like the one I ran or maybe even has the 6NZ pistons, injectors and cam swapped in. Maybe whoever built this glider already had a good MBN on hand to use but without looking at it we can never know these things for sure.
    Rame, ibcalm19, magoo68 and 1 other person Thank this.
