Cat power problems
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Natem18, Jul 1, 2020.
  1. Natem18
    Natem18 Bobtail Member
    14
    6
    Jul 20, 2019
    I have a 96 e model cat that I need help with. I bought this engine for a core about 6 months ago and had a very reputable guy do the overhaul on it and it runs great, most of the time. Sometimes, very randomly, no rhyme or reason it will start running really rough between 900 and 1200 rpms and blow out clouds of white smoke while starting off from a stop. It may do it a couple times in one day and then not do it again for a whole week. The other problem is that when starting off from a stop I can easily push 42 pounds of boost and it just up and goes like nothing but as soon as I reach my desired speed which is normally right around 70 I can only push 33 pounds of boost anymore and it feels like a dog compared to when starting off from a stop. I’d like to get it fixed.
  3. pushbroom
    pushbroom Road Train Member
    1,792
    7,438
    Sep 1, 2012
    A 96 e model would be a 40 pin ecm which did maybe 30lbs max boost. Has this been modified some? Whats the serial number or prefix
  4. Rubber duck kw
    6,092
    17,687
    Dec 9, 2017
    A good Borg turbo is all it takes to be pushing 40 plus pounds of boost on a 40 pin.
  5. Natem18
    14
    6
    Jul 20, 2019
    It’s a 1LW and yes it has been modified.
    Shawn2130 and 650cat425 Thank this.
  6. bad-luck
    bad-luck Road Train Member
    3,565
    6,646
    Nov 16, 2013
    Baltimore, Maryland
    Did you get new injectors? Sounds like a bad injector, on the mechanical side.
    magoo68 Thanks this.
  7. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,737
    Jan 30, 2010
    keep stroking.
    Sounds like air in the system. Crack in fuel lines or loose fittings. Also check fuel pressure to rule out check valve or transfer pump. Injector o-ring maybe fretting.
  8. Natem18
    14
    6
    Jul 20, 2019
    Yes he put in new injectors but like he said. Even new ones can be faulty. I’ll check the lines again but you’d think I have a fuel leak with cracks or loose fittings?
  9. bad-luck
    3,565
    6,646
    Nov 16, 2013
    Baltimore, Maryland
    They can. I am leaning towards an injector. If you had a loose fitting or cracked fuel line, you would be sucking air and I think it would do it all the time
  10. Natem18
    14
    6
    Jul 20, 2019
    Yeah that to. He did do a cutout test a while ago when I had time to stop in one day but that didn’t bring anything up
  11. bad-luck
    3,565
    6,646
    Nov 16, 2013
    Baltimore, Maryland
    Ok, maybe he can run one again.
