Cat Thermostat Housing Leak
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Smellfunny, Mar 16, 2021.
  1. Smellfunny
    Smellfunny Road Train Member
    1,446
    969
    Jan 28, 2012
    South Carolina
    I have a customer that has a C-15 Cat that I have replaced the Thermostat housing on twice and now it is bad again. He has also had it replaced once at another shop. When I do the job I always install new gaskets and Thermostats. It has fresh coolant 50/50. The hole is always in the same area. This is not his actual housing.(See picture) Any idea why this is happening? Housing.jpg
  3. Smellfunny
    1,446
    969
    Jan 28, 2012
    South Carolina
    I talked to the local CAT Shop and they told me it is possibly due to poor grounding issues. Going to check that out ASAP.
  4. A5¢
    A5¢ Medium Load Member
    389
    544
    Oct 30, 2017
    Did they mention why it would leak in the same spot? Is there a wire with the insulation worn off, arching the housing?
  5. Smellfunny
    1,446
    969
    Jan 28, 2012
    South Carolina
    Nope. Nothing loose or rubbing. I did as Cat suggested and checked for voltage in coolant but there wasn't any voltage.
  6. 062
    062 Road Train Member
    6,397
    34,216
    Oct 20, 2013
    Could it be cavitation? What psi cap is on it?
  7. Goodysnap
    Goodysnap Road Train Member
    3,811
    9,296
    Jul 12, 2017
    Photos of failed housings? Inside look?
  8. Smellfunny
    1,446
    969
    Jan 28, 2012
    South Carolina
    I think 10 PSI. Truck will be back Wednesday. Coolant is properly maintained (PH and Mix).
  9. Smellfunny
    1,446
    969
    Jan 28, 2012
    South Carolina
    Old ones are gone. Will take pictures of this one if I have to take it off. He had it patched for the moment.
  10. swaan
    swaan Road Train Member
    2,942
    4,376
    Jul 12, 2009
    BC canada
    Run a good ground wire from alternator mount to the frame. That is electrolysis .
    black_dog106 and Smellfunny Thank this.
