Cb amp hook up help
Discussion in 'CB Radio Forum' started by 19d, Mar 12, 2017.
  1. 19d
    19d Road Train Member
    1,290
    1,216
    Jan 12, 2016
    Sanford NC
    I'm going to hook up this little 1x4 hopper made amp .. I want to be sure I have what I need to not burn down truck. I have 8 gauge wire, will be running to the battery and ground post. 80 amp fuse will install at the battery and also run a 2nd ground to seat bolt. Does this sound ok? And where how to run cables to battery in freightliner is best?
  3. Dirtymartini15x
    Dirtymartini15x Light Load Member
    180
    114
    Oct 18, 2016
    You might want to bump that wire size up to 4 gauge especially since you will likely be over 10 feet of wire once you route it all. You also shouldn't need a second ground. As far as how to run your cables...look for grommets in the floor or firewall and run them through there. But I will say try and find a grounding point somewhere on the frame as close to the amp as possible.
    bored silly, rabbiporkchop and 19d Thank this.
  4. fargonaz
    fargonaz Road Train Member
    1,167
    4,583
    Feb 9, 2015
    Mesa, AZ
    You're playing with fire, instead of asking here you should be educating yourself. I hope it's your truck.
    rabbiporkchop Thanks this.
  5. 19d
    1,290
    1,216
    Jan 12, 2016
    Sanford NC
    Isn't educating myself sorta what I'm doing by asking questions on here?
  6. EZ Money
    EZ Money Road Train Member
    Is it a Cascadia?
    Should be a fairly easy job running the power.
    I came from the battery box through a rubber plug on the firewall and up the A pillar into the overhead cubby.
    Just be sure the fuse is right at the battery...and everything wrapped and zip tied so no rubbing.
    How many watts is that amp? 100 amp fuse may be to big!
    My 98VHP is a 4 pill and uses 35 amp fuses at the radio on both ground and hot side.
    Then I have a 50 amp right at the battery....
  7. fargonaz
    1,167
    4,583
    Feb 9, 2015
    Mesa, AZ
    Sort of, try asking the guy who makes the things, he has a facebag page.
  8. bored silly
    bored silly Road Train Member
    2,714
    656
    Jul 1, 2016
    a 98v has 8 mosfets in it unless it's been altered. And should only draw 25 amps on am
  9. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    This is what I would recommend.
    they are cheap enough on eBay.
    ExOTR and EZ Money Thank this.
  10. Ridgeline
    22,730
    123,516
    OK here is what I know ....
    The 1X4 dave made POS amp I have here draws 96 amps when it is running at full capacity - it also has Chinese knockoff toshiba transistors.
    SO I would use a 120 amp breaker (I don't think they make 110 amp) with at least 4 ga if you are running under 10 feet, the voltage drop may be as high as 6%, you would like to see less than 3% drop.
  11. bored silly
    2,714
    656
    Jul 1, 2016
    Quick question ridgeline even though it does not pertain to linears.. any ideas or thoughts as to why my swrs are at a 1:1 to 1:2 on channel 20 and 40 but up around 1:7 to 1:8 on channel 1 ??? Any thoughts or help in this is appreciated. I haven't been in this truck long it's another cascadia. I'm trying to work the bugs out thanks
