Cb amplifier
Discussion in 'CB Radio Forum' started by Chaos1488, Oct 30, 2018.
  1. Chaos1488
    Chaos1488 Bobtail Member
    I have a question about my cb amplifier . Awhile back ago someone keyed up on my amplifier . With the antenna disconnected ! Now when I hook amplifier up to watt meter . I get less wattage ! Than the radio itself puts out . Any answers on why it's doing this ? It's not even getting 3 watts max . Out of a two pill linear . Thanks !
  3. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Key up with no antenna hooked up, and it's "fried"....
    Popped the pill's! ..........It's "Smoked"....You can take the top off and look at the small resisters near the transistors and they will probably look black, which means the transistors are toast...
    These bugger's here is what your looking for...If they are brown or black they are toast, and so is the transistor next to it...(most likely both will be fried)
    rabbiporkchop Thanks this.
  4. rabbiporkchop
    9,678
    6,546
    Feb 9, 2012
    Wapwallopen, Pa
    Someone blew it up. Cheaper to buy a new one.
    jessejamesdallas Thanks this.
  5. shogun
    shogun Road Train Member
    6,075
    72,163
    Jan 23, 2009
    Doing a regen
    If you did pop the pills, buy some online from HG if they are 2879’s for about $60, then have someone replace them. You will have $90 or so compared to the $150-200 you’d spend on a new one.
    Timin770 Thanks this.
  6. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    He didn't say...but it depends on what Amp he has and what's in it...If it's something like a KL 203, it would be cheaper just to buy a new one.
  7. shogun
    6,075
    72,163
    Jan 23, 2009
    Doing a regen
    True. Figured it was a little class c like a fat boy.
  8. Meteorgray
    Meteorgray Heavy Load Member
    754
    597
    Jan 1, 2016
    I forgot to hook up the antenna on my Uniden 520 and KL203P amp a while back. When I keyed the radio with the amp off, the SWR shot into the bad zone. So, brilliant guy that I am, I turned the amp on and repeated the process to see the same results. After playing around with it for a minute, I realized I forgot to connect the antenna!! This is a constant risk for a slip-seat type hook-'em-up and pull-'em-out process that I go through.
    Fortunately for me, the radio and amp seem unharmed. I tested them both and found they are still producing the wattages they were producing before my little unintended experiment in radio abuse.
    I don't know why some fry quickly and, obviously, some don't.
    Slowmover1 Thanks this.
  9. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Just keying the radio up without a antenna connected doesn't nessesarly blow the finals...It's when you do that and start a conversation that blows everything up.
  10. Ridgeline
    22,730
    123,542
    The amp needs to be repaired, the amp transistors are shot, three watts out I bet one is bad and one is working.
    A good shop can fix it for under $100.
  11. Slowmover1
    Slowmover1 Road Train Member
    1,491
    1,210
    Oct 25, 2015
    Fort Worth
    God protects fools and children? That feeling? (Ha!)
